Slight feeling in steering during slow turning - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-09-2011, 10:13 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Default Slight feeling in steering during slow turning
My 2006 QC 4x4 has a very distinct feel through the steering wheel sometimes. It is very slight and only occurs when I'm turning at slow speeds such as in a parking lot. It doesn't do it all the time but it's fairly common. I haven't heard any noises. I can best describe the feeling as what it would feel like if you ran over a very slightly ribbed surface....like the "wake up" strip on the side of the road except much, much gentler.
I had assumed this was just feedback/road feel due to the 20" wheels and 285/50 tires but then I read that tie rod ends seem to be a problem for some of our trucks.
Is this normal? If not, does it sound like the symptom of tie rod ends going bad? If not those, any thoughts? Thanks ahead of time.
Old 03-09-2011, 10:46 PM
sullivan's Avatar
sullivan sullivan is offline
Vehicle: 2006 Dodge Ram Sport 5.7
Rep:202
sullivan has a spectacular aura aboutsullivan has a spectacular aura aboutsullivan has a spectacular aura about
I feel were both sorta on the same deal. My steering just doesn't feel right. I just replaced my outer tie rods with MOOG grease-able ends and had an alignment done. But my steering still feels like theres something wrong. I changed my power steering fluid, it helped and my fluid was low too. So overall change your fluid on your ram! It takes 1 bottle of ATF+4 tranny fluid, no Power steering fluid. Now, I am at the point where I am about to install new inner tie rods, I will state why below.
You can check your tie rods by simply jacking the front of the truck up and seeing if you can get any play movement in your wheel horizontally on either side. Grab your tire on either side and wiggle for play. If there is any movement its from the tie rod joints. Either the inners or outers, or both!
My outer ends were shot, and you could easily tell. And when I replaced them, I noticed the right inner tie rod had much more play then the left side. Therefore making me think I need new inner tie rods.
That's my situation. If you do need new tie rods, they aren't that much, and you can do them yourself. But you need an alignment right after!
Cheers
06' Sport - 3.92 Gears - Superchips - Bilstein Shocks - HellWig Anti-Sway Bar - Cooper Zeon LTZ - Viper Alarm & Remote Start - Halo Projector Lights - 5k HID Lows & Fogs - Custom Emblems - Magnaflow - CAI
Old 03-10-2011, 12:27 AM
Rep:367
If I do have a problem I think it is at the very beginning because the feeling is noticeable but very slight. Enough so that it could pass for normal steering feedback. To describe it a little better....it does kind've seem like it could be in the steering. It's like a gently pulsing through the wheel. I haven't even checked the fluid because until I read about the tie rod issues I had assumed it was normal.
So you refilled your pump with auto tranny fluid? What's the pros/cons to that? I guess there is a drain plug under there somewhere to drain the old?
Old 03-10-2011, 02:11 AM
Rep:367
Was just googling and found a TSB. #08-004, steering, hydraulic power assist, hoses, connections, and components. Said to cause a steering shudder at parking lot speed.
Anyone have any additional info on this? Thanks.
Old 03-10-2011, 02:22 AM
sullivan's Avatar
Rep:202
Our trucks USE ATF+4 fluid, which is also transmission fluid. There is no cons or advantages to it. All I did is flush out the oil gritty fluid, and put in new fluid and filled it up correctly.
I did a write up on the power steering fluid change, here: http://ramforumz.com/showthread.php?t=75277
That is all.
I would check your inner and outer tie rods. If you can grab them, and rotate them with your bare hand and strength, they need to be replaced. They should have little to zero play.
clunking/grinding from rear end while turning slow slikkwilly002 5.9L V8 Specific Topics 17 04-23-2013 08:58 AM
Fave Poems or Song Lyrics erm Off Topic Discussion 210 07-31-2011 10:33 PM
New Mods and a DIY for steering maintence sullivan Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 02-23-2011 11:10 PM
steering wheel has slight cockeye after 3in BL Inferno Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 02-04-2011 04:13 PM
slight clunk feeling UnLiMiTeD 2010 Dodge Ram Forum 25 10-17-2010 11:53 AM
