Old 03-10-2011, 11:42 PM
bubbakev87 bubbakev87 is offline
Vehicle: 1994 Dodge Ram 3500
bubbakev87 is on a distinguished road
Exclamation Brake light switch issue
I have a 94 ram 3500 that I have a problem where the tailights have running lights but no brake light.
Does anyone now if there is a way to bypass the brake switch to make sure thats the problem?
Old 03-10-2011, 11:50 PM
Rep:1882
Just remove the connector and put a jumper wire in place. If the lights work, you've found your problem.
Old 03-11-2011, 12:14 AM
Which of the 6 wires do I jump?
Old 03-18-2011, 09:11 PM
sundayhustler sundayhustler is offline
Vehicle: 1999 Dodge Ram 1500 4X4
sundayhustler is on a distinguished road
Jump pins 1 and 2, which are the two pins that are the farthest away from the plunger. Regardless, if you screw up and jump pins 5 and 6, you won't hurt anything.
When I jump pins 1 and 2, I'll usually get a small little spark, which seems to be a good indicator that power is flowing and the lights are working, at least on my truck.
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 08:19 PM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
Brake light issue scpo Electrical 2 11-29-2010 08:22 PM
Third brake light causing the brake lights to stay on? Due Electrical 7 05-19-2010 02:33 PM
Head light switch issue... 4doordodge4life Electrical 2 02-21-2010 11:53 PM
