Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 > MDS
MDS Multi Displacement System Discussion
MOPAR DECALS
Old 03-11-2011, 11:31 AM
E.L.D. 44's Avatar
E.L.D. 44 E.L.D. 44 is offline
Vehicle: 2011 Dodge Ram CC 4x4 Sport
Rep:388
E.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really nice
Default MDS off after header install
I have a '11 cc and just had my ARH lt's installed. I'm putting in the O2 simulators this weekend so currently I have a cel. My MDS also won't come on. My question is will the MDS system disengage when a cel is present or did they mess something up?
MY MOD THREAD
http://www.ramforumz.com/showthread.php?t=87541
Old 03-11-2011, 01:05 PM
Rep:3337
The O2 sensor fault could be causing issue swith the MDS, I can see this happening, but i'm not 100% on it. Best thing would be to see if it kicks back in after the simulators have been installed. Do the AR Headers not come with O2 extentions or did you delete the cats as well?
Old 03-11-2011, 03:00 PM
E.L.D. 44's Avatar
Rep:388
I got a day off work and decided to had them done but my other parts were still being shipped. I'll put on the O2 sims this weekend and hope for the best. The AR kit came with wiring extensions but not O2 extensions.
MY MOD THREAD
Old 03-11-2011, 03:05 PM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
can you not re-use the stock o2 sensors?
i'd have to agree with CD
DODGE the father RAM the daughter!
Old 03-11-2011, 03:07 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Those wiring extension are the O2 extensions the cats got moved back so you need those extensions to hook up the O2 sensors properly.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 03-11-2011, 03:55 PM
E.L.D. 44's Avatar
Rep:388
Maybe I can be clearer with what I am trying to say. I had the AR headers professionally installed Wednesday. All O2 sensors are hooked up using the provided extensions. The truck runs and operates as it should. I have a check engine light from the rear O2 sensors. There are no programmers for the 11 ram currently so I cannot program this code out. The only way I can get rid of the code currently is with a O2 extension or spark plug deflowler on the rear bank O2 sensor connected between it and the midpipe. I am hoping to have this part in today and install this weekend. Since the install my MDS has been inoperable. I was wondering if this is from the O2 check engine light or something else that I need to get addressed immediately. Aside from that the truck runs great and performs much better than before
MY MOD THREAD
Old 03-11-2011, 05:12 PM
RamTex's Avatar
Color: Stone White
Rep:366
Ah gotcha it took a few months and mine doesn't even pop codes anymore and I don't have cats lol
Old 03-12-2011, 06:38 PM
E.L.D. 44's Avatar
Rep:388
Well they haven't come in yet. I might be the only one to do headers without a tune so I don't know if this is a common problem. Hopefully the parts will be here soon and I can get rid of that pesky check engine light.
MY MOD THREAD
Old 03-16-2011, 12:51 PM
catsltd catsltd is offline
Vehicle: 2010 RCLB SLT 1500 Ram
Color: Mineral Gray
Rep:72
catsltd will become famous soon enough
Dont worry about your MDS it will work with or without codes.
Sometimes the eco light does not come on.
Once you get your 02 sims hooked up,disconnect the battery cables and touch them together for at least 20 seconds.
This will allow your ecm to reset and will relearn your o2 sensors,but it will reset your radio presets also.
If your radio does not reset you did not do it long enuff.
if you have your sims installed and still getting codes you most likely have an exhaust leak.
You have to get rid of the stock muffler to really get the extra power and mileage from the headers.
Your truck does not need a tune with a programmer to run good.
2014-True Blue SLT,CC 6.4 BOX.
Air suspension,Rambox,Navigation.Backup camera.
3:92 gears.
Old 06-25-2011, 02:05 PM
TxRam TxRam is offline
Vehicle: 2011 Ram 1500 Laramie
TxRam is on a distinguished road
Hey guys,
I'm concerned! I just ordered American Racing Long Tubes for my 2011 5.7, and I don't want any BS with codes and such. Has American Racing corrected this issue? Please let me know before I attempt the install.
Header install moparmike07 Dodge Ram Knowledge Base 9 05-06-2015 11:16 PM
Anyone have a LT header DIY install? DCollins3208 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 3 10-02-2010 01:26 AM
CAI + MDS Rasping? jimbodean Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 8 05-20-2010 12:46 PM
header bolts install Ramrob Exhaust 6 04-08-2010 10:40 PM
Header bolts install Ramrob 5.9L V8 Specific Topics 4 03-30-2010 08:42 PM
