Old 03-11-2011, 12:46 PM
BigHornRam2006's Avatar
BigHornRam2006 BigHornRam2006 is offline
Vehicle: 2006 Dodge Ram 1500
Trim Level: SLT Big Horn Edition
Color: Patriot Blue Metallic
BigHornRam2006 is on a distinguished road
Default SRT-10 Hood Issue....
During the summer of 2010 while in Iraq, I bought the SRT-10 Duraflex Fiberglass hood. Took the hood and my new grille to the body shop back in September of 2010. Had the hood shaped, blocked, painted, and had the fenders blended in for a little over $900.
To make a long story short, I cannot use my factory hood support lifts. The body shop said that if I use my factory hood support lifts I would crack the fiberglass hood. So then I was only running the truck only on the main latch, I could not go above 55 mph or the hood would tend to shake a bit. So in december I put my factory hood back on because I could not stand driving no more than 55mph, not for the distance I drive to work during the week. I plan on putting this hood back on this summer. I've looked everywhere and I cannot find them. Does anyone know where I can get hood lift supports for a fiberglass hood?
Dan R.
SGT, US Army
2006 SLT Big Horn
Old 03-11-2011, 12:52 PM
I push the skinny pedal
Rep:3308
Quick question... if your hood is like mine, and it uses the stock brackets, look at where the pistons mount. Mine are a full bracket that the hood bolts to, and the piston is attached to the bracket NOT the hood. This issue has arisen on the fords and chevys that the piston attaches directly to the hood and when it's down, the stock piston was pushing the hood back up as it was too strong. This isn't normally an issue on the dodges for the reason I listed above. My fiberglass hood has been on for two full years with NO cracks or issues running stock lift pistons.
Kurtis
Old 03-11-2011, 12:59 PM
The hood did come with the bolts installed already to bolt to the brackets on the truck, but I don't remember seeing attachments for the pistons on the hood. All I remember seeing on the hood itself was the two bolt studs to bolt to the truck.
Dan R.
SGT, US Army
2006 SLT Big Horn
Old 03-11-2011, 01:05 PM
Rep:3308
Then yours will be like mine. You'll have no issues the stock pistons since they don't bolt to the fiberglass hood.
Kurtis
Old 03-11-2011, 02:12 PM
Ok, So what exactly are you using to keep your hood down? How did you install yours? All I had was the main latch keeping my hood down and the hood bolted to the brackets, no hood supports or anything.
Dan R.
SGT, US Army
2006 SLT Big Horn
Old 03-11-2011, 02:30 PM
Rep:3308
The hood supports help keep the brackets from flexing I found. The rear of my hood does rise/flutter a bit (maybe a 1/2 inch), but that can't be helped due to the nature of a ram-air hood since the air pressure over the hood is less than under it (aka lift). Does the SRT-10 hood have a cowl in it or is it just the front scoop?
Kurtis
Old 03-11-2011, 03:07 PM
It has the front functional scoop. I have a picture of it in my gallery.
Dan R.
SGT, US Army
2006 SLT Big Horn
Old 03-11-2011, 03:26 PM
Rep:3308
Then you'll end up with some lift as the air can't escape from the back-side of the hood, but the stock lift pistons will help keep the rear from lifting as much at speed.
Kurtis
Old 03-11-2011, 04:06 PM
What If I installed hood pins in the front to help with the main latch? How much good would that do?
Dan R.
SGT, US Army
2006 SLT Big Horn
Old 03-11-2011, 04:26 PM
Rep:3308
Where is it lifting? The front or the rear? If it's lifting in the front, you need to raise the rubber bumpers (just turn them out) that are in the top rad crossmember; this gives the hood something to sit against instead of just 'rattling' around on the main latch.
Kurtis
Scatpack, bones 64 or anyone who has a srt or rumble bee hood scoop cscott1537 Dodge Ram General Discussion 9 02-26-2011 07:33 PM
SRT hood scoop info..Any installed one? MaRvO75 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 5 02-14-2011 10:35 AM
Vibration Issue WickedSix 5.7L V8 Specific Topics 5 01-13-2011 12:30 AM
Ram Air Hood and Products Dano61 Dodge Ram General Discussion 10 11-15-2009 04:12 AM
SRT10 hood & AMP ram air intake... CHILLZ HEMI Dodge Ram General Discussion 12 10-12-2009 03:06 AM
