Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum
Old 03-11-2011, 01:05 PM
Resident Technician
Rep:1915
Exclamation Urgent Info For '08 And Newer 4.7 Owners
I've recently discovered a problem with the top row coil packs that needs immediate attention. Last week I did an upper row plug replacement and when I tried to remove the coil packs, two of the boots tore beyond repair due to them seizing on the porcelin part of the plug. I thought this might be an isolated incident but after another plug replacement today, I discovered this is going to be a problem. The real downer is that plug boots are no longer available seperately from Chrysler and we couldn't locate any in the aftermarket so the entire coil pack must be replaced. Not that it much matters since the boots are only $3 cheaper than the complete coil pack.
If you're covered under the powertrain warranty and it should be covered if the service is done at the dealer but I'm not sure how it would be handled if this happens to a do-it-yourselfer.
My advice - remove the coil and apply dielectric grease to the inside of the boots where they dontact the porcelin part of the plug to prevent seizing.
I also checked the boots on the lower plugs and they came off cleanly but applying dielectric grease to these wouldn't be a bad idea.
Old 03-11-2011, 02:13 PM
Rep:3322
Ouch, that could really suck for a do-it-yourselfer... thanks for the heads up Randy
Old 03-11-2011, 05:28 PM
Resident Technician
Rep:1915
Hopefully someone will see this in time to save then the irritation of having to dig a plug boot out of the #7 or 8 cylinders. My description of this process would make a seasoned trucker blush with shame.
Old 03-11-2011, 09:21 PM
Resident Technician
Rep:1915
Just want to bump this one so hopefully some of the 4.7 owners see it and can avoid this problem.
Old 03-16-2011, 11:34 AM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1217
good stuff randy! Thanks, I will check mine tonite!
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. 60k Miles. 5100's @2.8 Adj Coilover front struts. 3" Lift done my way. BF-Goodrich Rugged Terrain T/A, Mufflex Muffler Delete, spray-in Liner, Mud Flaps, 20% tint, SS Side Steps, TruXedo Roll-up Soft Tonneau, SS Bull Bar, 10k Lumen 22" Solidex LED Bar, DZ Tailgate assist, TLC, AVS Visors and Bug Shield, K&N, XenonDepot 5000k HID Headlamps in projectors.
Old 03-16-2011, 03:13 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
Once again Randy, you are a valuable asset to all of us here on the forum. Thanks!
Old 03-16-2011, 04:00 PM
Juice420's Avatar
Juice420 Juice420 is offline
Vehicle: 2010 RAM 1500 SLT C.C.
Color: Brilliant Black Pearlcoat
Rep:946
Juice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to behold
Good info Randy!
Justin
Black Mamba- Flowmaster 40 series, Airaid CAI, 20% tint, GTO taillight covers, ATA nerfs, AVS in-channel ventvisors, Curt hitch receiver, Extang Revolution Tonneau, EZ-down tailgate damper, Recon smoked 3rd brake light, Custom painted engine cover
Black Mamba's Thread
Old 03-16-2011, 04:53 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Thanks for the heads up Randy, even though it doesn't apply to me it will definitely help out others!!
Dillon-aka, The Little Kid
Old 03-17-2011, 03:40 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
About a week late for me Just found this site seeing if this was a problem for others. I can answer what Chrysler will do about the problem for do it yourself croud. The top right row I had no issue removing the boots In fact there was enough grease on the plugs to make a mess. The top right side all four boots are welded to the plug. I ended up breaking the plugs off below the boot to remove the boot and top of the plug and a magnet worked great to remove the bottom halh of the plug Of course the boot os a dealer only item and dummy me decided to change the plugs on Sunday....The truck has a lifetime warranty but I would have to have it towed in and because I had damaged the boots they would not be covered under warranty and to add insult to injury they threatned to void the life time warranty because I had worked on the truck..nice ... so $150.00 dollars and four new coils she is back on the road and I am still trying to figure out how to get Dodge to honor their mistake
Bob
Old 03-17-2011, 05:02 PM
tmerritt530's Avatar
tmerritt530 tmerritt530 is offline
Vehicle: 2004 Ram 1500 4.7L "H/O"
Color: Graphite Metallic
Rep:91
tmerritt530 will become famous soon enough
Thanks for putting the word out!
My parents have an 08 4.7L, we haven't been into the plugs yet as the truck only has around 40K. My dad always puts dielectric grease on the boots for this reason. We did my truck around 30K miles ago.
2004 SLT RCSB 4.7L | 3.92 | OEM Off-Road wheels | Goodyear SilentArmor 285/70R17's | MBRP cat-back | H/O cams | H/O cyl heads
boots, coil packs, plugs, stuck
