Old 05-03-2011, 08:42 AM
redneck's Avatar
redneck redneck is offline
Vehicle: 1997 dodge ram
Trim Level: sport
Rep:16
redneck is on a distinguished road
yes you can do the TB mod in the 5.2L. and yes after you do that it will try and suck more air.
KAPOW! ohh! that sounded expensive!
Dodge the father....Ram the daughter!
Old 05-07-2011, 08:40 PM
hemifinder hemifinder is offline
Vehicle: 1999 Dodge Ram Sport
hemifinder is on a distinguished road
how did you guys get your air cleaner to fit?? i can't for the life of me get it past the wiring harness and even if i did there isn't room to even put the butterfly nut on. has anybody else had similar issues?
Old 05-07-2011, 11:09 PM
redneck's Avatar
Trim Level: sport
Rep:16
This is what I had to do to get it to fit... first put the bottom pan on, then put the air filter on, then put your threaded rod in. Last put your top pan on along with the nut. It takes some persuasion but it can work.
Old 05-08-2011, 05:55 PM
toddrod's Avatar
toddrod toddrod is offline
Vehicle: 2001 Dodge Ram
Color: Yellow
Rep:55
toddrod will become famous soon enough
Alright, I'm having problems doing this mod as well, I've had to go and purchase a air intake spacer (1") because the bottom pan wouldn't clear the throttle cable, and TB sensors. Now I can't get the "S" bolt tall enough to thread the wing nut on top. Has this been a problem for any one else out there?
Old 05-08-2011, 07:35 PM
is the bottom plate on yours flat? or does it go down farther than where it sits on the TB? Mine is flat and i ended up going with a shorter air filter. a 14x1 at the moment because that's all they had at the local napa, plan on putting a 14x2 on at a later point in time.
Old 05-08-2011, 09:43 PM
toddrod's Avatar
Color: Yellow
Rep:55
No the bottom plate on mine is not flat. I've looked at several different 14x3's at 3 different parts stores and they're all the same here, goes down further than where it sits on the TB. Kind of a pain in the A$$, but I think all I need to do now is find a 1/4" bolt 3 1/2"-4" long. The good news is I don't have to heat up and bend the bolt, it is already centered in the middle for me.
Old 05-08-2011, 09:50 PM
toddrod's Avatar
Color: Yellow
Rep:55
Another question I forgot to ask, What is the inlet size for the breather you guys are installing on the passenger side valve cover? And how are you removing the stock one with the line that goes to the oem air box? I was prying pretty good on it and it just keeps spinning around.
Old 05-08-2011, 11:57 PM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Post Hose
I had the same problem but backwards. It would slide in and out the hose fitting easily with a bit of pressure but where it connected to the pcv valve it would just rotate no matter how hard I would pull.
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 05-09-2011, 08:28 PM
toddrod's Avatar
Color: Yellow
Rep:55
So...how did you get the connection to the pcv valve loose?
Old 05-09-2011, 08:29 PM
toddrod's Avatar
Color: Yellow
Rep:55
sorry forgot to ask, what is the inlet size for the air breather on the valve cover?
4.7L build up begins! .40 over 10:1 + 10PSI + 100SHOT = OMG! AIR RAM Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 29 12-06-2010 01:21 AM
Cold Air intake question 06DodgeRam Dodge Ram General Discussion 21 12-28-2009 08:46 PM
Air intake question jjhwick119 Dodge Ram General Discussion 10 11-20-2009 11:58 PM
AEM Brute Force intake question mdh3pilot Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 5 07-19-2009 02:36 AM
BFI intake review by spedly semichigan Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 4 02-28-2009 10:35 PM
