Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 03-11-2011, 02:58 PM
fort mac mopar fort mac mopar is offline
Vehicle: 1996 dodge ram 1500
fort mac mopar is on a distinguished road
Default engine trouble
I have a 1996 dodge ram. It will start and idle but when i press the gas pedal it bogs out and has no power can anyone help me with this problem
Old 03-11-2011, 03:43 PM
marshall23 marshall23 is offline
Vehicle: 96 ram 1500 5.9 gas 4x4 33in t
Trim Level: club cab
Color: silver/marroon
marshall23 is on a distinguished road
sounds like the problem i had when i took out my tranny get a 1/2 inch wrench and flat head screwdriver. taqke the flathead and take the air filter out then the 1/2 inch and jump up and reach to the back of the engine and the fire wall on passenger side you should feel the tranny fill tube right behind it is the crank position sensor two bolts. mine had bed wires.
Old 03-11-2011, 03:54 PM
Resident Technician
Rep:1909
I fail to see how a faulty CKP sensor can cause a bog. A bog occurs when too much air and not enough fuel enters the cylinders. Start by checking fuel pressure and volume. After that, look into the TPS as a possible culprit.
Old 03-11-2011, 10:25 PM
Magnum488's Avatar
Magnum488 Magnum488 is offline
Vehicle: 05 1500 4X4 Daytona
Trim Level: Daytona
Color: GoMango
Rep:13
Magnum488 is on a distinguished road
Could be a plugged catalytic converter...An easy check is to pull the upstream (before the cat) 02 sensor and run it. If it runs better the cat is clogged, if not , well at least nothing was damaged testing.
12 Charger R/T R&T, Dynomax, Trinity, 180 stat
05 Daytona QC GoMango 4X4 Long tubes, Y-pipe, Airaid, NX 100 shot, Superchips
03 Durango's 4.7's 4X4's SLT one white one green
95 Ram 1500 4X4 MP computer, shift kit, more..
Old 03-11-2011, 10:44 PM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
wow. before i even read your post, i was thinking the same thing...
+1
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 03-17-2011, 08:39 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
i was gonna say tps or MAP sensor possibly,
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 03-23-2011, 11:29 PM
al4171990 al4171990 is offline
Vehicle: 1997 Ram 1500
al4171990 is on a distinguished road
i would like to check fuel pressure on my truck having some of the same problems but cannot find a test port anywhere on the fuel rail where are you supposed to test fuel pressure at??? thanks
engine trouble griffin 5.2L V8 Specific Topics 2 12-15-2010 12:38 PM
engine trouble. smoking dodgeman9859L 5.9L V8 Specific Topics 2 09-11-2010 10:07 AM
Trouble diagnosing engine problems. iRESQu Jokes/Humor 9 05-10-2010 10:39 PM
Truck shaking when gas is depressed dirtsurferus 5.9L V8 Specific Topics 12 01-31-2010 02:19 PM
5.9 V8 Engine Trouble Skipp 5.9L V8 Specific Topics 19 01-27-2010 10:26 PM
