Old 03-11-2011, 05:52 PM
BiggBerger BiggBerger is offline
Rep:43
BiggBerger is on a distinguished road
Default Mobil 1 Extended Performance
Does anyone use this? What about the filter? Mobil1 claims that you only need to change your oil every 15k miles.
Old 03-11-2011, 06:40 PM
RamTech RamTech is online now
Rep:1909
I've got in my engine right now as an experiment to see how well it does. I only have about 2500 miles on it so far and I plan to pull a valve cover around 5k and every 1500 or so after that to make sure everything is still clean. I recommend Wix, Purolater, K&N or another name brand filter with the exception of Fram. I don't like they way they're made and I won't use them.
Old 03-11-2011, 06:51 PM
I agree with that ^^^^ on the test and checking.
I used Mobil 1 in a GM LT1 in a '95 ImpalaSS for 140K miles before I tore it down to do a 383 stroker. The engine main bearings, cam bearings and crank journals were in fantastic shape!
I changed my oil every 6,000 miles with that forumlation.
Old 03-11-2011, 07:03 PM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2004 dodge ram 1500
Rep:31
charlieb is on a distinguished road
bigberger if u want u can drain alittle out and have it tested at 5k intervals then u will know for sure.cat(skidsteer) charges between 20-25 $ for analysis.then u make ur service intervals as u please after that.good filters wixx,k&n,napa gold,amsoil,royal purple.all synthetic oil is # 1 with me
Old 03-11-2011, 07:31 PM
Rep:43
I use a Mobil 1 filter. Should I just change the filter at 5k or let it go for the 10k - 15k miles with the oil? If the oil really does last this long I should only need to change my oil once a year.
RamTech I saw your thread after I posted. Its amazing what you find when you search, but I didnt see you mention any filter changes before changing out the oil.
Old 03-11-2011, 08:14 PM
Rep:1909
I'm as yet undecided but I may change it at 5000 miles and top off the oil. I don't do a lot of off road driving so the filter isn't a huge concern at this point.
Old 03-11-2011, 08:48 PM
Rep:43
I do about 85% highway driving and I dont drive hard. Please post if you do or dont change the filter at the 5k mark. I think when I need to change my oil again Im going to use the Extended Performance, I just want to know everything I can before then.
Old 03-17-2011, 02:21 AM
williamhartle's Avatar
williamhartle williamhartle is offline
Vehicle: 2007 dodge ram
Trim Level: st
williamhartle is on a distinguished road
i use a mobil 1 filter and mobil 1 syn oil i let it go to 9-10k and have had no problems
2 inch leveling lift 3 inch body lift, 34" bfg mud terrain TA KM2, straight pipe, vararam intake, superchips cortex, Firestone air bags, skyjacker n8000 shocks rear, s8000 front struts, painted head lights, tinted tail,cab mount light, big shiny chrome balls.
Old 03-17-2011, 03:30 PM
chefred112's Avatar
chefred112 chefred112 is online now
Vehicle: 2005 Dodge Ram
Rep:656
I run amsoil in mine which is every 25k miles... been running it since 06 and have no ill effects..openned the motor up a couple times when changing cam/heads and have also had oil samples analyzed to make sure it's still holding up, motor was clean... approaching 200k on my 05
Old 03-17-2011, 04:47 PM
dustin72's Avatar
dustin72 dustin72 is offline
Vehicle: 2013 Dodge Ram1500 4x4
Rep:48
dustin72 is on a distinguished road
I run Mobil 1 Synthetic 5w20 in my 2010. Also run Mobil 1 Synthetic 5w30 in my 2006 Trailblazer SS (factory recommended oil). I change oil every 5000kms, mostly because I drive a lot of short trips and don't get the engine to operation temperature.
Black SRT10 22's with 305/45/22 Nitto NT420S Tires, 6000k Low and Fog HID's, Debadged, Tint, Custom Mopar Badges, S&B Intake, Magnaflow Muffler, Superchips Tuner
Mobil 1 Extended Performance RamTech Product Reviews 17 04-14-2011 06:51 PM
Diesel Tunes Performance Chip knsram Dodge Ram General Discussion 5 02-04-2011 11:08 AM
Hurst Performance debuts THE LEGENDARY black & gold COLORs on the Hurst Challenger!! GT Automotive Industry News and Dodge Press Releases 0 03-30-2009 07:56 PM
