Old 03-11-2011, 07:56 PM
mattdott mattdott is offline
Vehicle: 1998 dodge ram 4x4
mattdott is on a distinguished road
Default overdrive
my truck shifts out of overdrive for second then locks right back up. it started out doing it once in the morning the first time it engaged. now it does it every time i hit a hard bump but so far it only happens in the mornings on the to work. it doesn't do it on my way home or at least not yet. i take the same road to and from work so i am hitting the same bumps. i am going to check to switch on the brake pedal to see if it is loose. past that i am open to suggestions cause i am really not a transmission guy.the extent of my know how stops at older ones without solenoids.
Old 03-12-2011, 06:00 PM
Magnum488's Avatar
Magnum488 Magnum488 is offline
Vehicle: 05 1500 4X4 Daytona
Trim Level: Daytona
Color: GoMango
Magnum488 is on a distinguished road
I think it's in the brake switch......if it does it often, just touch the brake pedal when driving that will unlock the converter, so does letting off the throttle so keep it steady. If it quits acting up the problem is the brake switch...there is hardly no adjustment to play with! But I got mine to work with a light spring on the brake pedal arm to hold it up. That was like 10 years ago! I was under the dash and saw it and thought what's this for? then I remembered!
12 Charger R/T R&T, Dynomax, Trinity, 180 stat
05 Daytona QC GoMango 4X4 Long tubes, Y-pipe, Airaid, NX 100 shot, Superchips
03 Durango's 4.7's 4X4's SLT one white one green
95 Ram 1500 4X4 MP computer, shift kit, more..
545rfe 4.7 Overdrive Lagging Woot1337 4.7L PowerTech V8 Specific Topics 4 04-03-2014 09:25 PM
Overdrive Dann Dodge Ram General Discussion 10 08-13-2011 09:29 PM
99 1500 5.9 Overdrive Lock-up Problem. delineated 5.9L V8 Specific Topics 3 01-19-2011 06:15 PM
2000 dodge ram 5.2 p1740 TCC Sol (Overdrive Solenoid Performance) Vivalaram 5.2L V8 Specific Topics 2 10-21-2010 10:27 AM
A question about overdrive gear... DodgeGuy85 5.2L V8 Specific Topics 4 07-30-2010 09:35 AM
= Copyright a Network Site =Ad Management by RedTyger
