02 quadcab rearend rebuild - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-11-2011, 11:55 PM
dannkim dannkim is offline
Vehicle: 2002 ram 1500
dannkim is on a distinguished road
Default 02 quadcab rearend rebuild
I just got done rebuilding the rearend and everything seemed to go well. The only thing is is now i have a whinning sound when let off the throttle. Any help would be appriciated.
Old 03-12-2011, 12:25 AM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2017 ram express quad cab
Trim Level: express
Rep:37
charlieb is on a distinguished road
let people know what u have did u rebulid 9.25 lsd with stock clutch packs?people cant help u unless u tell them what u have /what fluid/friction modifiers
Old 03-12-2011, 09:32 AM
Resident Technician
Rep:1915
How much backlash and pinion bearing preload did you have when you set up the rear end?
Old 03-12-2011, 10:53 AM
Idk about the backlash and all. Just tightend Until I had minimal play without being tight and bustingthe pinion gear. The only thing Im worried about is i wad to use my inpack gun the tighten the pinion nut to take the slop out of the bearings. As soon as it went away i stopped. I didnt use any shims cause none came out. I filled with valvaline limited slip and spun axle by hand for about 20 min from each side to get the fluid all around b4 putting power to it. There are no noises or play anywhere until i let off the throttle and thats is when it whins.
Old 03-12-2011, 11:48 AM
Resident Technician
Rep:1915
There's your problem - You didnt set up the rear end properly and one or more of the specs are out. Could be backlash, pinion TTR, pinion depth...
Old 03-12-2011, 12:07 PM
I got a guy coming over to look at it. We will c in a bit!
Old 03-12-2011, 05:07 PM
Ok! I had it close but not right. My backlash was off which when i let off the throttle the rear end started driving the tranny. Repositioned and set it to basically nothing, could hear the play in it but u cant see it at all!! I learned alot in a few hrs. Thx alot.
Old 03-12-2011, 05:34 PM
Resident Technician
Rep:1915
Zero backlash is bad too. You need to be between .005-.008"
Old 03-12-2011, 05:36 PM
Sounds like the bearing preload and backlash were off.
How's it running now?
Old 03-12-2011, 07:59 PM
Its running like it did b4 the outer wheel bearing went out. Not one single noise and as smoothhhhh as can b!!!
My 1998 5.9L Engine rebuild 5point9LARAMIE4X4 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 68 05-20-2016 03:52 PM
Vib feeling from rearend jrshatch Suspension 7 11-22-2010 08:59 PM
need help, rearend is bineding? nitro1965 5.7L V8 Specific Topics 14 09-20-2010 05:05 PM
What year of factory wheels will fit my 2003 Dodge 1500 quadcab? Dhunter Dodge Ram Wheels And Tires 3 04-26-2010 01:08 AM
Is this a good price on tranny rebuild bwoodredkneck LD RAM - General Discussion 2 01-22-2009 02:42 AM
