Old 03-12-2011, 01:33 PM
HemiSooner's Avatar
HemiSooner HemiSooner is offline
Vehicle: 2008 Dodge Ram 1500 Big Horn
Color: Silver Metallic
HemiSooner is on a distinguished road
Default Diablo Predator Custom Tune
i watched an installation video on YouTube for the Diablo Predator, my question is at the end the guy said if you send in your engine code or something they would make a "custom" tune for your truck.... so what is different from the custom tune they will send you vs the performance tunes that are already pre-loaded on the Diablo??
Old 03-12-2011, 05:58 PM
What is different will be what your truck data logs show as how the engine runs stock and with a canned tune. Normally, they will tweak up a custom tune to match how your engine runs. Most run pretty much the same within a set of parameters. What the custom tune does is narrow down that performance to gain maximum output, HP, torque and efficiency.
Old 03-13-2011, 04:08 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
also, custom tunes will take into account what your mods are since none of us really mod exactly the same as the next guy.. "canned" tunes (the preloaded tunes on diablo for example) don't know how big your cold air intake or how much flow your exhaust has.. by datlogging, a tuner (a person, not the handheld device)..can manipulate numbers so that your motor runs at optimim..
Old 03-13-2011, 09:59 AM
06 BigHorn's Avatar
06 BigHorn 06 BigHorn is offline
Vehicle: 2012 Dodge Ram
Trim Level: Express Quad Cab
Color: Deep Cherry Red
Rep:153
06 BigHorn has a spectacular aura about06 BigHorn has a spectacular aura about
Do they charge for a custom tune? If so whats the price?
It's a truck, not a cream puff
Old 03-13-2011, 01:11 PM
HemiSooner's Avatar
it seemed as long as you had the Diablo Tuner that the custom tune came with it free, all you have to do is email them and they will email you back with the custom tune. then you just have to save it to your Predator and upload it to your truck.
Old 03-13-2011, 01:12 PM
HemiSooner's Avatar
so when i run the Diablo on my truck will it automatically keep "data logs" or is that something i have to do myself with some other device??
Old 03-13-2011, 01:45 PM
chefred112's Avatar
Rep:656
no, you have to setup for datalogging, choose the pids (parameters) on the tuner, then drive around and start the datalogger ... depending on who is doing your tuning, the pids they want may be different from others.
Also, I don't know of anyone that tunes for free unless it came as a package deal. i think sean (hemifever) does them for $250 (unlimited tunes i think)
this is from my tuner:
Here's a Basetune and the PID list that I normally use for N/A vehicles.
When installing the tune or any revision I may send be sure to reset the adaptives(pull PCM fuse) and reset all parameters with the Predator.
Install the tune and let it learn for a couple of days then do a log.
When logging be sure to vary your driving style to fully populate the tables.Not all PID's are used by all vehicles
so you may not find them all but most will be there.
Also include any A/F #'s you have for WOT.
ACT (F) or IAT
ECT (F)
OPEN LOOP FA (AFR)
RPM
MPH
1/1 Long Term ADAP(%)
1/1 Short Term ADAP(%)
2/1Long Term ADAP (%)
2/1 Short Term ADAP(%)
Baro (PSI)
PRATIO (PRatio)
AVG Total Working PW (us)
KNK Sensor 1 (V)
KNK Sensor 2 (V)
KNK TOTAL RETARD (DEG)
MAP TO USE (psi)
RAW TPS 1 (V)
RAW TPS 2 (V)
ACTUAL SPARK CYL 1 (DEG)
ACTUAL SPARK CYL 2 (DEG)
ACTUAL SPARK CYL 3 (DEG)
ACTUAL SPARK CYL 4 (DEG)
ACTUAL SPARK CYL 5 (DEG)
ACTUAL SPARK CYL 6 (DEG)
ACTUAL SPARK CYL 7 (DEG)
ACTUAL SPARK CYL 8 (DEG)
BASE SPK (DEG)
THROTTLE BLADE POSITION (%)
Old 03-13-2011, 01:51 PM
chefred112's Avatar
Rep:656
...the diablo does the datalogging...the key is, after datalogging you have to download the logs to a pc. if you start to datalog again, it will write over previous datalog... I prefer to have the diablo hooked up to truck, and have my laptop hooked up to diablo at the same time, that way i can keep saving logs in real time plus it's cool to watch all the pids record on screen of my laptop.
Old 03-13-2011, 02:29 PM
chefred112's Avatar
Rep:656
here is a visual of what I'm talking about..I'm actually doing some datalogging today to send to tuner...
Old 03-13-2011, 02:36 PM
JackDaniel's Avatar
JackDaniel JackDaniel is offline
Trim Level: Rumble Bee #897
Color: Yellow
Rep:101
JackDaniel will become famous soon enoughJackDaniel will become famous soon enough
Like he said if you go with a custom tune at a dyno place he can take into consideration your mods you have on your truck and tweak everything to get the maximum power from everything. BTW Chefred watched ur track videos, ur truck is amazing!!!!
1970 Nova 402BB
1971 Nova parts car
2003 Harley Softail
2004 Ford Mustang GT
2005 Rumble Bee (for sale!!!!)
Dyno sheet 09 ram r/t diablo tune only SPEEDFREAK Dodge Ram R/T 18 05-23-2011 01:11 AM
87 octane tune for diablo predator cscott1537 Dodge Ram General Discussion 3 02-23-2011 08:45 AM
Does the "Eco" light get disabled with Diablo tune? Raptor1000R 2010 Dodge Ram Forum 9 09-01-2010 03:40 PM
THE TRUTH, IS DIABLO TUNE WORTH THE MONEY? dyno RAM RT SPEEDFREAK Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 33 01-06-2010 11:34 PM
