Old 03-17-2011, 09:27 AM
DaSOB's Avatar
DaSOB DaSOB is offline
Vehicle: 1998 Dodge Ram Ext Cab
Trim Level: SLT Laramie
Color: Light Driftwood Satin Glow
Rep:51
DaSOB will become famous soon enough
No doubt there is a similar bearing in the upper part of the column, but getting to that one would be a lot more work. Plus, I'm told that the columns are pressed together and that none of the internal parts are available separately. You're probably doing the best thing you can, but you might try using some good spray grease (and not the cheapo white stuff that comes from China) instead of WD40. WD40 is a staple for us rednecks, but the downside of it is that it gradually dries out and loses lubrication properties. Plus, over time it can build up a gum that can cause sticky parts to stick together even worse.
I'm a gun collector, and one of our top no-no's is using WD40 to lube your weapons, precisely because of the sticky gum that develops. So I would get some ZEP or something with equal properties.
Ah Luv Muh Truck!!
http://www.ramforumz.com/signaturepics/sigpic2117_1.gif
Engine oil seal where power steering shaft attaches jmcamille Cummins Diesel Specific Topics 3 12-16-2013 09:16 PM
Borgeson steering shaft Mac Suspension 10 07-06-2010 11:25 PM
Steering shaft Mac Suspension 15 06-29-2010 12:53 AM
Body lift steering extension problem solved JMaxx93 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 0 05-26-2010 12:08 AM
Borgeson Steering Shaft, anyone tried it? Wraith Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 1 03-21-2010 09:11 PM
