Old 03-13-2011, 07:20 PM
lwalston's Avatar
lwalston lwalston is offline
Vehicle: 2010 Dodge Ram 3500 6.7
Rep:93
lwalston will become famous soon enough
Default Gps
I have mine hard wired in under the console, It also has the built in charger
Les
Old 03-13-2011, 08:31 PM
Guinnessboy's Avatar
Guinnessboy Guinnessboy is offline
Trim Level: sport
Color: lighter than black, darker than white
Guinnessboy is on a distinguished road
i dont have pics but will post some tomorrow if somebody wants to see......i have the sport interior with the center console as well.....i have a garmin nuvi and believe it or not i found a way to lodge the mounting cup in the hole that is normally occupied by the 4wd knob ( yes i have 2wd) it wedges in their very clean and when the gps is attached to the holder it practically sits flush to the dash just to the left of the fan blower knob....just enough room to angle it towards the driver and slightly up. its in there pretty good and never had fallen out. I run the power cord along the drivers seat side of the console to the rear power plus at the back of the center console. Very very clean.
Old 03-13-2011, 08:48 PM
BDM218's Avatar
BDM218 BDM218 is offline
Vehicle: 2013 Ram 1500 Bighorn
Trim Level: Bighorn
Color: True Blue Pearlcoat
BDM218 is on a distinguished road
Guinnessboy- I forgot about the outlet in the rear. If I find a cupholder mount, then I could run mine down the passenger side seat and plug it in in the back. I thought about putting it in the cupholder earlier, but I didn't think I would get good reception. Maybe I'll have to look for a longer power cord and a cup holder mount.
Old 03-13-2011, 10:20 PM
Bighert3rd's Avatar
Bighert3rd Bighert3rd is offline
Vehicle: 2011 Ram 1500 Sport (HEMI)
Trim Level: Sport (HEMI)
Rep:60
Bighert3rd will become famous soon enough
I mounted my GPS right above the stereo. I took out the little tray that's above the stereo and made my own mount and attached it to this tray, then just snapped the tray back into place. It's actually very stable and does not move at all. The power cable I just ran over to the glove box and inside the glove box I put it through a small hole and then ran it under the console and up through the other tray that's next to the shifter.
Mods: Sport Hood-True Duals with Magnaflow 14'' mufflers-magnaflow 4'' tips-Magnaflow X pipe-Airaid CAI-PowerAid TBS-Truxedo Low Pro Cover-In Channel Vent Visors-22'' 2 Crave Wheels
Old 03-14-2011, 07:41 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
I've got a Magellan that I mount to the windshield just to the left and below the rear view mirror (on the rare occasion that I need it),
For power I ran an extension cable from the rear outlet that runs along the bottom of the center console (mostly tucked under the lower edge) to up under my dash. From there I have a Y adapter where I've plugged in another extension cord that I ran under the dash to the left where it connects to the cord from my radar detector that comes down the a pillar, and a 3rd extension cord that runs to the right under the dash (that was fun to route) and up into my lower glove box.
When I need/ want to use my GPS I'll slip it into the mount, and then plug it in to the spot that I created in the glove box. I'll then try to route the wires where they're out of the way, gathering the excess into the glove box, where I'll wrap 'em up with a twisty tie. It keeps things nice and neat.
It's kind of dark out now, but I'll try to get a couple of pics of my set up a lil later
Exco
Bill
Old 03-15-2011, 10:33 AM
armycanuck armycanuck is offline
Vehicle: 2011 Dodge Ram Crew SLT
armycanuck is on a distinguished road
I also mount my Garmin to the drivers side vertical silver trim on the center console, right on the top where it is mostly flat. It does take some trial and error but as long as you mount it using a little surface cleaner or water, it will stay.
Try putting the suction cup on as far back and to the right you can on the flat area, it should work fine.
I only have mine plugged in when i use it and then it's just a straight line down to the AC lighter outlet. I sheep shank the cable to the proper length so there is no extra dangle.
Old 03-15-2011, 06:47 PM
BDM218's Avatar
Trim Level: Bighorn
Thanks for all the replies and pictures. It's given me a few new ideas. I'll probably try a few this weekend!!!
SuperCharged Hemi RAM thanks to Magna Charger azzo540 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 207 06-07-2013 09:30 AM
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 03:59 PM
Power Outlet/Airbag switch swap StartParsley Electrical 2 09-06-2008 07:21 PM
