4wl boom question lo - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 03-13-2011, 04:05 PM
jackedupdodgeman jackedupdodgeman is offline
Vehicle: 1999 dodge ram 1500
Color: maroon
jackedupdodgeman is on a distinguished road
Default 4wl boom question lo
I put my 99 dodge 4x4 in 4wl the other day while in some mud and stomped it and heard a extremelly loud boom under me and felt it...any suggestions? Can you hit the gas too hard while in 4wl ?
Old 03-13-2011, 04:38 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Not too sure but they say something has to give. If the wheels don't break loose the shafts and differentials break.
Old 03-13-2011, 05:01 PM
sk8noregon's Avatar
sk8noregon sk8noregon is offline
Vehicle: 2008 Dodge Ram
Rep:637
sk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to all
Do you still have 4wd ? If not then it could be driveshaft of transfer case, not to hard to tell once you look at the driveshaft.
"Rocky and Bullwinkle"
Join the "Mineral Gray Metallic Ramz Group" here !
Old 03-13-2011, 05:12 PM
Speckdaddy's Avatar
Speckdaddy Speckdaddy is offline
Vehicle: 07Ram2500Mega4X4 99RamQuad4x4
Rep:36
Speckdaddy is on a distinguished road
It might not have "locked up" yet.
I have noticed the 4wd light comes on the dash before the front axle engages.
So it will give me a thump if im too heavy on the gas before lock up.
Old 03-13-2011, 09:58 PM
Color: maroon
ok speck...can you tell me abouit how long it takes to engage? this is my first 4x4 and its all kinda new to me. Any infor would be greatly appreciated
Old 03-14-2011, 06:50 PM
Magnum488's Avatar
Magnum488 Magnum488 is offline
Vehicle: 05 1500 4X4 Daytona
Trim Level: Daytona
Color: GoMango
Rep:13
Magnum488 is on a distinguished road
To engage it takes until all the gears line up and slide into place. When I go into 4WD I give it a gentile hit of the throttle after shifting into 4X4 and you can usually feel it lock in. Don't try to shift it into 4WD while the rear wheels are spinning and the fronts aren't. You can shift on the fly when everything is turning at the same speed, like when I turn onto a snowy road I will coast and shift into 4WD. For 4 wheel low you need to shift the trans into neutral and shift to low range quickly...If you spend to much time with the transfer case in neutral it will grind trying to get into gear (hi or low range) In that case turn off the engine leave the trans in neutral shift the transfer case and fire it up and be on your way
12 Charger R/T R&T, Dynomax, Trinity, 180 stat
05 Daytona QC GoMango 4X4 Long tubes, Y-pipe, Airaid, NX 100 shot, Superchips
03 Durango's 4.7's 4X4's SLT one white one green
95 Ram 1500 4X4 MP computer, shift kit, more..
coolant line question 97ram1500 Heating & Cooling 1 09-28-2010 04:18 PM
2/4 lowering question jjhwick119 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 11-13-2009 09:31 PM
Newbie question dodgeramdude Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 6 09-16-2009 06:00 PM
Grease fitting question. pghram1500 LD RAM - General Discussion 2 07-22-2009 08:12 PM
AEM Brute Force intake question mdh3pilot Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 5 07-19-2009 01:36 AM
