Old 03-13-2011, 04:17 PM
Johns HEMI 2500's Avatar
Johns HEMI 2500 Johns HEMI 2500 is offline
Vehicle: 2007 Dodge Ram 2500 Hemi 4x4
Trim Level: SLT/TRX4 Off Road/SP
Color: Light Khaki Metalic
Rep:18
Johns HEMI 2500 is on a distinguished road
Default Levelling kit or Bilsteins
I want to install some 35's on my truck.Which would be the best way to go,a levelling kit or Bilsteins. I do a bit of off-roading nothing serious.
If You Can't Run With The Big Dogs, Stay On The Porch
Recon Smoked Cab Lights, Smoked Tail Lights. Big Rig Ice Running Lights, White Lightning Tail Gate Bar. Tech Tubes wheel to wheel nerf bars. 2" Revtek Leveling Kit. 35x12.5x17 Nitto Trail Grapplers
Old 03-13-2011, 06:40 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
i would go with the bilsteins bud
Old 03-13-2011, 07:54 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
Take Platinuminjected's advice you won't regret it. you'll get a levelled truck AND better ride and handling.
Old 03-14-2011, 09:09 PM
ScatPak07's Avatar
Rep:970
Yep I agree with the above. I have had both the spacer and 5100s as a level for my truck. I hands down would recommend the 5100s to anyone that wants to level the truck. If you are going to do some off roading then they will be great for you. They also make bigger tires handle better which is awesome out of a leveling kit.
Old 03-15-2011, 03:30 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Sorry but you cant take there advise. The 5100 is a great shock but they dont make a ride height adjustable shock for 2500's.
2500 has a solid front axle with coil springs so you'll have to go with a leveling spring or a leveling spacer.
You can actually keep you stock shocks with a leveling kit, spring or spacer, but an extended shock will help with a better ride.
Old 03-15-2011, 03:12 PM
Crash's Avatar
Rep:401
Good catch Stragshcky, I'll admit I didn't even look at his bio before answering. I'll give you rep for setting us straight. That's whats great about this site everyone has something to help fellow members out
Old 03-15-2011, 04:21 PM
Color: Mineral Gray
Rep:177
Had it not been for his username I probably would have seen Hemi to the right side and went with it too!
Old 03-17-2011, 03:02 PM
rev.buttons rev.buttons is offline
Vehicle: 2004 dodge ram 2500
rev.buttons is on a distinguished road
While we are on the subjet of a level on the 2500, can i throw in a question too?? I have a 04 2500 hd and i had thought about leveling it but when i did the measurements the front was at 40in and the rear at 41in. All the levels i see say for 2-2.5in front level. obviously i am guessing i dont need these(i had seen the hell bent steel level kit). is there something i'm missing here? thx guys
Old 03-17-2011, 03:44 PM
Rep:18
Thanks for the help guys. I quess I will have to go for the levelling kit. Does anybody have any any thoughts on the Truxx leving kits. It seems to be the most common around here where I live.
Old 03-17-2011, 06:44 PM
Color: Mineral Gray
Rep:177
Where did you measure from? You need to measure from the center of the axle to the lip of the wheel well. Also what opitions/motor do you have in your truck? The weight of the motor shouldnt make much of a difference but you may have a TRX4 or maybe a plow package that gives you a taller spring.
Truxx are way to expensive for a spacer in my opinion. I have a Hell Bent Steel 2" and am extremley happy with it. $65 shipped
It actually sits a little higher in the front then the back now with the 2" spacer but you cant tell (like .5" or .75" I think)
levelling kits and air bag kits GregBel 5.7L (345 cu in) HEMI V8 Specific Topics 10 01-19-2012 09:24 AM
Bilsteins are junk belle Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 03-07-2011 08:04 PM
Pro comp levelling kit and bump stops wetcoast Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 06-15-2010 01:54 AM
2007 1500 2WD 1500 Sport/want Bilsteins and coil spacers/rear blocks DanoHB Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 03-21-2010 10:59 PM
02 2500 levelling kit diesel04 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 2 12-30-2009 08:52 AM
