Old 03-17-2011, 07:07 PM
rev.buttons rev.buttons is offline
Vehicle: 2004 dodge ram 2500
rev.buttons is on a distinguished road
Originally Posted by Stangshcky12 View Post
Where did you measure from? You need to measure from the center of the axle to the lip of the wheel well. Also what opitions/motor do you have in your truck? The weight of the motor shouldnt make much of a difference but you may have a TRX4 or maybe a plow package that gives you a taller spring.
Truxx are way to expensive for a spacer in my opinion. I have a Hell Bent Steel 2" and am extremley happy with it. $65 shipped
It actually sits a little higher in the front then the back now with the 2" spacer but you cant tell (like .5" or .75" I think)
I measure from the ground up to the center of the wheel well. Also I bought the truck used but did look at the original purchase sheet and it does have the plow package. So does thaty mean there is no need to level or are there other level kits out there designed for this. U mentioned yours was higher, didx you have the plow package too?
Old 03-17-2011, 09:25 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
With the plow package your going to have a taller spring thats a little bit stiffer to help carry the extra weight of the plow on the front end.
You could put a leveling spring on your truck that would replace your current springs and level your truck but a spacer will cause you alot of problems (You would probably be over 3" of lift and the geometry of your driveline will be way off)
There is actually no NEED to level your truck unless you dont like the look of its stance now.
I did a leveling kit on mine cause 35's were rubbing on the lower fender after I pushed the wheels out some
Old 03-18-2011, 07:27 AM
Well that's good to know. It actually already looks pretty level. I was just asking cause my wife would rather me do other upgrades to the truck instead of putting a 4in lift on it. So I've been doing some research. Other than diff covers(for looks and to keep cool) do you have other sujggestions as to some good upgrades that won't break the bank?
Old 03-18-2011, 10:09 AM
shrek shrek is offline
Vehicle: 2013 Ram 1500 CC Sport
Rep:38
shrek is on a distinguished road
I have a 1500 and was wondering if i can get by with just shocks to level my truck or do i need the spacer as well
Old 03-18-2011, 02:17 PM
Color: Mineral Gray
Rep:177
For 1500s its either or. I didnt know much about 1500s till I joined this forum but most of these guys will swear buy just using the Bilstien 5100 ride height adjustable shock.
For your 2500 I would say an intake and exhaust are good investments, you could always argue that they'll help with full mileage if you have too.
You could also get a little bit bigger of a tire next time they need replaced. Stock tire size is 265/70/17 I believe. You can without a doubt fit 285/70/17. If you could find something around a 305/75/17 or 305/70 they would probably fit without rubbing also. If you have stock wheels you could even go up to 35x12.5 but the wider tire will rub a little bit on your lower control arms at full turn.
Take a look around the forum, theres plenty of different mods guys are doing that may suit your taste better then mine too!
Old 03-18-2011, 04:25 PM
Johns HEMI 2500's Avatar
Johns HEMI 2500 Johns HEMI 2500 is offline
Vehicle: 2007 Dodge Ram 2500 Hemi 4x4
Trim Level: SLT/TRX4 Off Road/SP
Color: Light Khaki Metalic
Rep:18
Johns HEMI 2500 is on a distinguished road
I'd like to get the Hell Bent Steel kit, but their not available in Canada. With the shipping,duty and brokerage fees it's probably about the same price as Truxx.
If You Can't Run With The Big Dogs, Stay On The Porch
Recon Smoked Cab Lights, Smoked Tail Lights. Big Rig Ice Running Lights, White Lightning Tail Gate Bar. Tech Tubes wheel to wheel nerf bars. 2" Revtek Leveling Kit. 35x12.5x17 Nitto Trail Grapplers
Old 03-18-2011, 04:59 PM
Color: Mineral Gray
Rep:177
Yup missed that part too. I' just going off of what I can find online but there shouldnt be any duty on it since there made in the USA (wooo NAFTA) I know its $40 dollar flat rate shipping from hell bent steel to canada, not sure but I think taxes, conversion and brokerage would be about $15.
Still cheaper then Truxx website price of $227
levelling kits and air bag kits GregBel 5.7L (345 cu in) HEMI V8 Specific Topics 10 01-19-2012 09:24 AM
Bilsteins are junk belle Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 03-07-2011 08:04 PM
Pro comp levelling kit and bump stops wetcoast Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 06-15-2010 01:54 AM
2007 1500 2WD 1500 Sport/want Bilsteins and coil spacers/rear blocks DanoHB Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 03-21-2010 10:59 PM
02 2500 levelling kit diesel04 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 2 12-30-2009 08:52 AM
