Old 03-13-2011, 05:57 PM
tks07ram's Avatar
tks07ram tks07ram is offline
Vehicle: 2007 Dodge Ram
tks07ram is on a distinguished road
Default Water under the backseat of a 2007 Ram
I have a 2007 Dodge Ram. Last night I opened up the storage compartment under my rear seat and found about 2 inches of water in the compartment. Pulled it in the garage this morning and have pretty much determined that it is leaking around the rear window somewhere. I have the power sliding rear window. Has anyone else had this probelm that could give me an idea where to start?
Old 03-15-2011, 05:30 AM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
Boy 2 inches of water sounds very rapid considering it was overnight. One would assume this leak would be fairly obvious. The only way I could think of (or how I would do it) is to just wash my truck and see where the heck it would come from Lol. Other than that i'm clueless.
Old 03-24-2011, 10:22 AM
bones06's Avatar
bones06 bones06 is offline
Vehicle: 2008 Ram 1500
Trim Level: SLT Big Horn QC
Rep:92
bones06 will become famous soon enough
I had the exact issue last year on my 08. They removed and resealed my rear window but that didn't fix the issue for me. The next time it went in they found that the air exchange vents behind the rear seats were warped and letting water in. If you go outside your truck and look at the space between the outside rear cab and the front of the truck bed you will see a black louvered vent on both sides. Hope this helps, as thats where my water was coming from.
Magnaflow SI/SO Smoked stainless tip, Anzo LED Lightbar, Spectre Profab #9932 CAI. Euro Dezigns Xenon Krypton 8500k, Stampede Pocket Style Fender Flares, Bilstein 5100 series shocks, VHT Niteshaded Tail Lights and 3rd Brake Light, 295/70/17 Nitto Trail Grapplers MT/XD Spy Wheels
Old 03-24-2011, 10:36 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Also check your high level brake light. If it's loose or has a bad gasket, it will allow water to drain into seat wells.
brad
Interested in one of my mods?
Old 03-24-2011, 10:40 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
I had the issue in my 06 and found leaks at the rear window and brake light.
Drop by the newbie section and introduce yourself.
A big hello and a warm Carolina welcome. I hope you enjoy the best RAM ForumZ.
Old 03-24-2011, 10:44 AM
tks07ram's Avatar
Thanks guys. I am gonna check my third brake light first because I recently put a replacement third brake light in I bet that's it
Old 03-25-2011, 04:36 AM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
my third brake light leaked on my truck. i shop vac'd almost two gallons of water from the under seat compartment. put a thin film of clear rtv and havent had an issue since. hoping the bulbs don't burn out now...
Old 10-01-2011, 12:49 PM
cableman cableman is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: laramie
Color: mineral gray metalic
Rep:32
cableman is on a distinguished road
Figured id post my findings on my water leaks. I too had water on the drivers side rear storage compartment.
My sunroof needed to be adjusted cause one side went down too far and let too much water in for the drains to handle.
The driverside sun roof drain would not let water out unless you poked at it between the bed where it come out. I snipped a small piece off with a scissor.
Now the rear power window would fill and not drain. I found the drains! Their about 6.5"'s from the windows end. I took a small straw which fit inside my air gun and blew in the track under the cable, this is where the drains are. You will be able to here the air rushing outside. I also black siliconed the bottom corners of the exterior seal which let less water in.
I am now leak free
Old 11-11-2011, 06:36 PM
MrG
Default water in rear under back passenger side
i bought a 2008 Ram 1500 Big horn 7 months ago recently and found water in the compartmet under the rear passenger seat the seat dosn,t get wet just the storage under.
Old 11-12-2011, 10:41 PM
maybz maybz is offline
Vehicle: 2007 Dodge Ram Laramie
maybz is on a distinguished road
I have the same problem. Just pulled out the cable to clear drain holes and now my slider cable is screwed up. Is there an easy way to get to the motor without pulling out the back seat? Thanks
Water high in cab? yagottaregatta 2010 Dodge Ram Forum 31 07-05-2011 05:45 AM
leaking water...again. jamestorque9 Body & Interior 9 01-09-2011 07:33 AM
Inline water filter jayhkr Washing & Waxing 9 05-28-2010 05:15 PM
28-ounce water pump hemiv8dodgeram1500 Jokes/Humor 13 01-31-2010 05:49 PM
Water on the moon?! 98sst Off Topic Discussion 13 11-15-2009 07:50 AM
