Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Place your Ad Here!
Old 03-13-2011, 05:00 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
Default HID issue that needs fixing FAST please
For all you lighting pros...
Ran into an issue installing my lights. Got half way done (passenger side fog and low beam) installing my 6k lights. Specifically bought from hidextra.com cause of some reviews shows no flickering of the lights..
For those with a 4th generation truck 4 lamp, I bought just low beam kit n fogs, no high beams...you remember seeing those two circular pieces that twist that seal the outside of the housing. I cut a small hole in the low beam circular cap to feed the wiring and the bulb from HID kit. I didn't have to cut, splice, etc it was all plug and play and easy to figure out (I'm not light savy at all)
Put it all back together to test out the lights and they work. However the fogs 9145 bulbs are perfect n bright. The low beams H11 are bright but they start flickering / dimming. They do have moments where no flickering is going on and its perfect then it goes back to it. THE WEIRD thing, is when my truck is completely off and I turn my lights on, all lights work fine. As soon as I turn on my truck the passenger side starts to flicker/dim. I made sure to mount the ballasts in the same spots as the driver side. So I start thinking to myself, maybe its a bad ballast? On the flip side, a bad ballast would probably not allow the HID to run properly while my truck is off right? Could it be a bulb? Same thing, why would it be perfect when the truck is off? I am lost and annoyed with this passenger side low beam light
What did I do wrong or what can I do to fix it?
Fast replies are appreciated lol I am on shift tomorrow at the fire dept and would love for my lights to run good before I gotta be gone for 24 hours.
Old 03-13-2011, 08:22 PM
Big Daddy's Avatar
Big Daddy Big Daddy is offline
Vehicle: 2009 Crew Cab / 3.92 rear end
Trim Level: SLT Big Horn
Color: Stone White
Rep:917
Big Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to behold
Sounds like what my HID's did when I installed them except the fogs went in several months after the low beams (I didn't do highs). Got the flickering with engine running, didn't get the flickering on just battery on both installations. After a few crank cycles they did sort themselves out though. My thoughts is the computer had to learn the differences in power requirement from the standard to the HID's. Once it sorted it out I haven't had any more problems. Give it a few cycles and see what happens. And with that said if it doesn't work out on its own I'm pretty much useless on the problem so maybe someone else will chime in pretty soon.
Big Daddy
Marching to Mamasita's beat for a real real long time...
____________________
Dennis
Old 03-16-2011, 12:53 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
I had the same issues with my HIDeXtra kits. Ended up fixing it by going with a relay harness for the lows. This by-passes the TIPM and supplies power to the lights directly from the battery. You still use the switch as the relay trigger so everything looks stock from the outside too. I called HID eXtra and complained and she sent me the relay harness for free.
Good luck.
Old 03-16-2011, 01:20 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Rep:1443
http://ramforumz.com/showthread.php?t=70224
Hmmmmmm.....HID Relay Buzzing Ramathorne Custom Dodge Ram Interior and Exterior Lighting 29 03-19-2013 10:14 PM
Dealerships: A User’s Guide RootBeer Dodge Ram Knowledge Base 3 05-04-2012 05:03 PM
Bought new HID bulbs but have problems str8hemi Custom Dodge Ram Interior and Exterior Lighting 9 09-28-2011 02:39 PM
Help hid conversion kit wont work on fog lights pacificflip72 Custom Dodge Ram Interior and Exterior Lighting 22 02-09-2011 01:20 PM
Vibration Issue WickedSix 5.7L V8 Specific Topics 5 01-13-2011 12:30 AM
