Old 03-13-2011, 05:27 PM
alfonso318's Avatar
alfonso318 alfonso318 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: 1500 (5.9L)gas
Rep:42
alfonso318 is on a distinguished road
Default Check Engine Light
So i've been babying and fixing this dodge for quiet some time now...my check engine light has come on about 4 times since purchasing it...everytime it says bad t-stat...first time it was actually broken but the following 3 times nothing appears to be wrong with the t-stat...just yesterday the light came on...i'm assuming its t-stat again...what would be throwing this code all the time if the t-stat is good? Just gettin sick of changing the t-stat and flushin all the coolant...
Old 03-13-2011, 06:14 PM
What about the coolant temp sensor? Check it and the connection to it.
Old 03-13-2011, 06:28 PM
alfonso318's Avatar
Rep:42
where is that located?
Old 03-14-2011, 09:54 AM
kdt75 kdt75 is offline
Vehicle: 1999 Dodge Ram 2500 4x4
Trim Level: SLT Laramie
kdt75 is on a distinguished road
Alfonso...
It's to the left of your thermostat housing...there's your t-stat housing...an inlet from your heater core...then left of that is a little sensor threaded into the intake...careful with it...I just replaced my plenum gasket and ended up breaking two of those sensors...they seem to be a little weak where the plastic meets the brass...hope this helps!
Good luck!
Kyle
Old 03-14-2011, 01:29 PM
alfonso318's Avatar
Rep:42
thanks for the heads up bout that...i'll look for it if the code is actually a t-stat...i'm almost positive its a t-stat tho...
Old 03-17-2011, 08:07 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
if it was the t-stat your truck would have symptoms of being too cold all the time or on the erge of overheating or just overheating, if it was the temp sensor then it wouldnt read the coolant temp. does your coolant temp guage work?
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 03-17-2011, 08:48 AM
Rep:1909
This isn't necessarily true. A sensor can be bad and the gauge can still work but be inaccurate.
Old 03-22-2011, 08:14 AM
98redbull2's Avatar
Rep:52
yea i just reread my thread and donno why i said that lol
check engine light code, please help interpret! MOPAR stallion 5.9L V8 Specific Topics 7 12-01-2010 11:15 PM
Check Engine light col Oil Change 14 11-26-2010 09:23 PM
Check Engine Light on? sixwheeler 5.9L V8 Specific Topics 1 11-10-2010 03:11 PM
180 stat throws on check engine light? MoparMadness08 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 14 08-19-2010 07:22 AM
Check engine light col 2009 Dodge Ram Forum 14 12-11-2009 05:34 PM
