Old 03-13-2011, 07:25 PM
tone11's Avatar
tone11 tone11 is offline
Vehicle: 2006 Dodge Ram Megacab Deisel
Color: Gray
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Rep:40
tone11 is on a distinguished road
Default Rear Sliding Window Switch
I have the switch for my rear sliding window but cant seem to find the male 8 terminal that plugs in the back. It goes between the 2 seat heater buttons.
I had this window installed after the old solid one was smashed in. It didn't come with the truck so now I am wiring it in. I know about the kit but its too late unless i can get the wire harness separate.
Can anyone help me find this plug??
Thank You
Anthony
Old 03-13-2011, 07:45 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Did your truck have the connector at the back for the window?
Just wondering if your truck has the wiring. BTW - the plug for the switch while being 8 pins, only has 7 wires. (3- Black, 1- Pink/Yel, 1- Orange/Lt. Grn, 1- Lt Grn/Orange & 1- Red/Violet)
Sometimes when the connector is there but not used, it is fully taped into the harness to make it very difficult to find.
brad
Interested in one of my mods?
Old 03-13-2011, 07:49 PM
tone11's Avatar
Color: Gray
Rep:40
No, it originally was a solid window, so i was told by the dealer that it doesn't exist within the harness. It seems you know what I need but where do I find it??
Thanks
Old 03-13-2011, 07:52 PM
brad12kx's Avatar
Rep:2581
Yikes!.....How handy are you with wiring? I can get you the factory wiring drawing if that helps.
brad
Old 03-13-2011, 07:53 PM
tone11's Avatar
Color: Gray
Rep:40
Well.........I have it working already. I figured it out with a couple toggles
Old 03-13-2011, 07:54 PM
tone11's Avatar
Color: Gray
Rep:40
Thanks
All i need is the plug in the back, I can figure the rest out
Old 03-13-2011, 07:56 PM
brad12kx's Avatar
Rep:2581
So your looking for the plug to make use of the factory switch....I get it now!
Likely the best option would be an auto wrecker. I ma not aware of being able to order the plug from Dodge. Usually you have to order the $45,000 harness to get it.
brad
Old 03-13-2011, 07:59 PM
tone11's Avatar
Color: Gray
Rep:40
Yup, I'm having a heck of a time finding it.
It was easy to get it to function but looks bad being a couple of toggles. I want it at least to look right, even though it not.
Thanks
Old 03-14-2011, 11:27 AM
Rep:1882
I checked the Mopar connector kit site and this particular plug is not available. A salvage yard is your best bet.
Old 03-14-2011, 06:06 PM
tone11's Avatar
Color: Gray
Rep:40
Thanks, I went there to and they show the switch only. I think my year being an 06 it didn't come with it. I looked at an 08' specs and found the switch but no plug.
Its called a power sliding backlite.
How do I disable the rear sliding window. persuazion Dodge Ram General Discussion 7 03-20-2015 11:13 AM
2008 Switch bezel Rear sliding window and heated seats TALLA Custom Dodge Ram Interior Modifications - Custom Audio / Video 3 01-16-2011 04:11 PM
F.S. 2009-11 rear sliding power window LARAMIE382 Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 4 01-06-2011 07:39 PM
Rear sliding window broken HEMIPOWER19 Body & Interior 6 11-15-2009 02:45 AM
Sliding rear window vs fixed window w/ defroster ronnchy Dodge Ram General Discussion 5 10-04-2009 10:28 PM
