Old 03-14-2011, 09:59 AM
RichJHU's Avatar
RichJHU RichJHU is offline
Trim Level: SLT 4WD
Rep:89
RichJHU will become famous soon enough
Default Slight leak in front axle
I got underneath my truck yesterday and noticed a slight leek in my front axle. It looks like it is a grease like substance coming from where the passenger side axle goes into the transfercase.
Anybody have this issue?
I put a 2" leveling spacer in the front end could this have caused it?
Old 03-14-2011, 10:11 AM
Resident Technician
Rep:1909
If you're talking about where the axle tube goes into the differential, it's probably just the sealer that goes between the two.
Old 03-14-2011, 10:32 AM
RichJHU's Avatar
Trim Level: SLT 4WD
Rep:89
That sounds right, I will keep an eye on it to see if it leeks any more. Thanks!
Old 03-14-2011, 01:47 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Color: Burgandy
Rep:160
I was just under my truck yesterday, same thing......, mine was just starting to form a drop, I did have some oil on the lower control arm bracket, very little, something you could see the wind was getting at. I wiped mine up around the axle tube seal and I guess I will wait to see what becomes of it, the shitty thing for me is the closest dealer is 4 hours away.
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ MINI MAX 75 HP TOWING TUNE/ OD TUNE COMING SOON!
Old 03-14-2011, 01:52 PM
RichJHU's Avatar
Trim Level: SLT 4WD
Rep:89
I'm going to stop by the dealer in the next few days. I'll let you know what they say.
Old 03-14-2011, 02:06 PM
Color: Burgandy
Rep:160
I would be interested to see what they say!
Old 03-15-2011, 06:54 PM
clatla's Avatar
clatla clatla is offline
Color: Snow White
Rep:31
clatla is on a distinguished road
I had a small drip on the floor on my gararge since shorly after the last oil change (at dealership). When I brought it back for the next oil change I told them about it and low and behold they had to replace some seals in the front diff. it was ofcourse under waranty. So far so good.
Front axle seal change latitud 5.7L V8 Specific Topics 4 08-14-2011 02:15 PM
Front Axle Replacement Leadchunker Dodge Ram 4x4 - Offroad Discussion 4 01-21-2011 11:23 PM
Leak on Passenger Side of Front Axle? goldendaddie Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 03-25-2010 04:51 PM
Front Axle leak info gregster 2010 Dodge Ram Forum 10 03-09-2010 03:10 PM
front axle 99 ram slt Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 01-14-2010 07:40 PM
