Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram – 1994 to 2001 Dodge Ram Trucks > Suspension
Place your Ad Here!
Old 03-14-2011, 05:35 PM
DTigers87 DTigers87 is offline
Vehicle: 2001 Dodge Ram 1500
DTigers87 is on a distinguished road
Default Having trouble finding a lift
I have a 2001 Ram 1500 Sport "Off Road" Package, and its a pain in the ass to try and find a lift for. Im looking for a 5" lift kit, but all the ones I am interested in say they will not fit "Off Road" model. From that I have gathered it basicly just came with a factory 2" taller coil. I was looking at a 5" kit by Topguncustomz that utilized coil spacers, but it said it wouldnt fit the "Off Road" model...Any advice?
Old 03-15-2011, 09:46 AM
danv802008's Avatar
danv802008 danv802008 is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: ST 4x4
Rep:53
danv802008 will become famous soon enough
http://www.4wheelparts.com/Lift-Kits...ght+(in.)_PQ=5
Quite a few came up on this site for it...you might try giving them a call and ask about it...they helped me a lot when i was looking for a lift for my truck.
MODS List: Pro Comp 6" Suspension Lift | Nitto Dune Grapplers 35's | Moto Metal Skull Wheels | Flowmaster 50 Series HD SI/DO | AFE Stage 2 Pro 5 CAI | HyperTech Performance Tuned
Old 03-18-2011, 11:22 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
The lifts work, but there's some things you shouldn't do.
BTW, the off road springs aren't any taller just a lot stiffer.
Lifts are rated based on a standard non off road ram. Example: If you add 5 inch front coils to an off road, you only lift it 3 inches over stock but it's still 5 inches (based on a standard ram) and 35 inch tires will fit if you used all the other components.
Now 5 inch coil spacers are another matter. Thats gonna give you about 7 inches over a stock ram. But it also will not allow you to set your front end geometry unless you install a long arm kit and the proper track bar and pitman arm. Don't run a 5 inch spacer anyway. Use 7 inch springs. In other words if you want to lift an off road ram 5 inches over its STOCK hieght, use a 7 inch lift. Honestly, thats too much for a 1500. Ther's a lot of extra work involved, and durability is reduced.
If you only need a couple more inches, you can use a 3 inch spacer (or 5 inch springs) with the correct arms. Use a tough country 5 inch track bar bracket to reset and center your axle, and a drop pitman arm to restore your steering geometry. The ride will be a bit harsher, but you'll be able to run 35 inch tires. Use a 3 inch AAL in the back if you want some rake and load carrying ability, or a 2 inch AAL to level the truck.
Oh last detail, longer sway bar links. You'll increase your roll rate without them.
Having trouble finding a lift. DTigers87 Newbie Checkin! 12 03-14-2011 11:25 PM
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 09:49 PM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 11:25 PM
Tax Time and i want srt 10 rims but having trouble finding them veilofmaya7 Dodge Ram Wheels And Tires 27 01-12-2011 12:56 PM
