Old 03-14-2011, 06:21 PM
belle belle is offline
Vehicle: 2011 Dodge Ram Laramie
Trim Level: laramie
Color: rugged brown two tone
belle is on a distinguished road
Default MDS question
How do I turn the MDS off? What does this affect? I read that with a leveling kit and bigger tires, the truck would run smoother with it turned off. Is this true? Thanks.
Old 03-14-2011, 06:40 PM
Resident Technician
Rep:1915
You can turn off the MDS buy activating the tow/ahul option of by shifting from drive into the 5 range. If you want to permanently disable it, you'll need a tuner.
Old 06-25-2011, 11:02 AM
roll roll is offline
Vehicle: 2011 dodge ram
Trim Level: slt 4x4
Color: hunter green pearl
roll is on a distinguished road
Why would you want less mpg ? These are smooth running trucks! A friend put larger tires on his truck then when back too smaller and now it rides better with the smaller tires! Don't mess up a good thing !!!!
Old 06-25-2011, 02:23 PM
Skillets's Avatar
Skillets Skillets is offline
Vehicle: 2011 Dodge 1500 Big Horn Hemi
Color: Dark Cherry Red
Rep:12
Skillets is on a distinguished road
the mpg is no effected that much when you turn off the msd. really the only time i have the msd on is when i'm on the interstate. which then, the msd helps alot on mpg, 19.4-21.3.
i have 3.55 gears. that makes a little difference vs 3.92s
Old 06-25-2011, 04:04 PM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
Mds doesn't help much in the city but does a lot on the highway, well technically the fact that you're in 5 and not in whatever gear the computer puts you in. Cause highway at 80 with 4.10 I'm at about 3000 rpm but when I take it out of 5 it drops to less than 2500. But mds kicks in so it sounds horrible with my dumped exhaust
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 06-25-2011, 04:33 PM
11HEM1's Avatar
11HEM1 11HEM1 is offline
Vehicle: 2014 Dodge Ram 1500 Crew
Color: PX8- Black Clear Coat
Rep:31
11HEM1 is on a distinguished road
Can you use the tow/haul with cruise
Debadged -4" Mopar Lift - XD Cranks - 325/60/20 Nitto Grapplers
Old 06-25-2011, 04:34 PM
garner's Avatar
Rep:46
Yes. Shifting into 5 and tow/haul do the same thing
Old 06-27-2011, 07:50 AM
Al E. Gator's Avatar
Al E. Gator Al E. Gator is offline
Vehicle: 2014 Ram 1500
Color: Deep Water Blue Pearl
Rep:30
Al E. Gator is on a distinguished road
Somewhere around here there is a post that says Chrysler engineers recommend shifting to 5 instead of using tow/haul to disable MDS. I don't know the reason behind it, I just remember reading that was the engineer's opinion.
Old 06-27-2011, 11:16 AM
Second Life's Avatar
Second Life Second Life is offline
Vehicle: 2011 Ram 1500 Crewcab
Trim Level: Outdoorsman 4x4
Color: Deep cherry red
Second Life is on a distinguished road
Tow/haul won't let you go in overdrive. Putting it in 5 will.
Tow/haul keep the gear longer, wich take more gas. Putting it in 5 change gear like it normally would.
So i guess it's better for fuel economy to put it in 5.
Truxedo LoPro - Westin Premier 6'' Oval tubes - Sonnax line pressure booster - Dee Zee rubber bed mat - Magnaflow 12259 - K&N Aircharger - Bilstein 5100 set at 2.8'' - BullyDog GT for Hemi Plus
looking at 06 1500's to buy mds question 3rdgenluder 5.7L V8 Specific Topics 19 04-05-2011 11:45 AM
MDS Question Silver04Ram MDS 6 03-06-2011 09:31 PM
Quick Question (MDS) akesel13 5.7L V8 Specific Topics 3 11-30-2010 12:22 PM
MDS Exhaust question TRIPOD Exhaust 37 06-14-2010 11:46 PM
CAI + MDS Rasping? jimbodean Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 8 05-20-2010 12:46 PM
