Old 03-14-2011, 07:53 PM
ramaddict2010 ramaddict2010 is offline
Vehicle: 2010 Dodge Ram 2500
Trim Level: TRX 4
Color: Black/Mineral Grey
ramaddict2010 is on a distinguished road
Default Question about lift ?
I want to put 35" tires on my 2010 Dodge 2500 TRX4 but I've been told that all I need is a 2" leveling kit then I was told I need a 4" lift kit . Anyone have the answer?
Old 03-14-2011, 09:25 PM
ScatPak07's Avatar
Rep:970
You have a 2500 so you should be alright with just the leveling kit. Your truck sits higher from the factory then the 1500s. If you had a 1500 then a 4" lift would be the way to go to fit 35" tires.
Old 03-14-2011, 11:39 PM
Tonix's Avatar
Tonix Tonix is offline
Vehicle: 2011 dodge ram
Rep:26
Tonix is on a distinguished road
i have a 1500 with 35's with just a leveling kit. had to do a kminor mod to the inner fenderwell to avoid rubbing. all is good now.
6" Procomp lift, 20" KMC Monster wheels, 35x12.5R20 Nito Mud Grapplers
Old 03-15-2011, 02:23 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
You can fit 35's on a 2500 stock.
If you have 35's on stock wheels you will rub a little bit on the lower control arms(with or with out a leveling kit)
A leveling kit will give the truck a much better stance but your TRX4 already have a +1" spring in the front over any other model 2500.
As far as I know you cant just use a leveling spacer on your truck becuase its already a higher spring but you could use a leveling spring, you would only see +1" from where your truck sits now if you got a +2" leveling kit
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 10:49 PM
Spindle Lift Question!! goodjohnson Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 01-27-2011 01:46 PM
Question about torsion bar lift highdesertcowboy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 10-28-2010 01:51 AM
body lift question? pullin48 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 05-13-2010 03:08 PM
2WD lift question OFTravis Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 10-05-2009 01:37 PM
