Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Place your Ad Here!
Old 03-15-2011, 12:00 AM
RumbleBee05's Avatar
RumbleBee05 RumbleBee05 is offline
Vehicle: 2005 Dodge Ram 1500
RumbleBee05 is on a distinguished road
Default Engine Coolant Help!!
I have a 05 1500 and my engine coolant reservoir completely emptied less than 2 weeks later after being filled. I have had no warning lights come on or seen the engine temp gauge running high. I have no clue what is going on with it and would appreciate any and all help as to try and figure out what is going on with it from anyone who has had this issue before.
Thanks RumbleBee
05 1500 flame red 5.7 HEMI super charged 400hp
Old 03-15-2011, 04:36 AM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
Thanks RumbleBee
Check the under the radiator cap and see if there is still coolant. Maybe run a pressure test and check the heater core as well.
If there is no coolant at all I would check any hose coming to or from the radiator. It would be likely you'd have a leak, obviously. Don't forget to check freeze plugs. my buddy blew one a small section of his freeze plug and all the coolant rushed out in a matter of seconds. We had to cycle water through it to find the leak.
I've also witnessed a toyota pickup from the early '90s dump all of it's coolant with no sign of a leak. We had even filled it up and to this day it hasn't leaked.
Coolant is weird stuff my friend.
Old 03-15-2011, 07:46 AM
Resident Technician
Rep:1915
A bad radiator cap can cause this. If there are no readily visible leaks, you may want to replace it since it will be cheaper than pressure testing the cooling system. If coolant continues to vanish after replacing the cap, then have a pressure test performed.
Old 03-24-2011, 09:30 PM
Thanks for the help. I meant to get on here a few days ago. I traced the leak to the thermostat housing. I removed the hose and pulled the thermostat out. The rubber gasket had dry rotted and broken causing the fluid to leak. Cost about $40 to fix with a new thermostat and a gallon of coolant. For future reference buy a thermostat with a black gasket. It has a better compound and will last longer. Thanks for the suggestions.
1500, coolant, engine, hemi, overheating
Intake Belly Pan Gasket RamTech Dodge Ram Knowledge Base 3 02-27-2015 03:30 PM
Simple engine coolant question sullivan Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 3 02-23-2011 01:33 AM
Coolant leaking from AC Compressor...WTF? 96Ram1500 Heating & Cooling 8 09-26-2010 10:08 PM
Truck shaking when gas is depressed dirtsurferus 5.9L V8 Specific Topics 12 01-31-2010 02:19 PM
Painting Engine Cover Incognito LD RAM - General Discussion 15 01-11-2010 11:14 AM
