2003 3.7l gas mileage - Page 5 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram MPG Zone
Diesel Forums!
Dodge Caliber
Dodge Ram MPG Zone Discuss your MPG woes and helpful hints here!
Place your Ad Here!
Old 12-23-2011, 08:55 PM
chambers chambers is offline
Vehicle: 2004 Dodge Ram 1500
Rep:29
chambers is on a distinguished road
My mileage has been sucking pretty hard here lately. I used to get 18-20 mpg no problem, but lately it's been 16-17.5. Plugs have recently been changed from ngk iridiums back to stock v-power, clean air filter, and ran fuel injector cleaner all w/ no effect. I've never seafoamed a vehicle but I'm thinking about it now. All my maintenance is up to date and the mileage has been down for a good while.
Old 12-25-2011, 08:49 AM
Rep:4253
I would love to see 18-20 mpg! Mine increased after the tune up, air filter and throttle body cleaning but I don't think it was quite that good lol! I've never Seafoamed a vehicle myself, either but I'd be curious to see how it works for you if you do it. Do you do a lot of stop and go city driving? My mileage sucked when I did but now it's mainly highway and I see a difference.
Old 12-25-2011, 12:52 PM
Rep:29
It's mostly highway, to and from work 60/40 or 70/30 highway/city. It's just odd b/c for a good while I was getting 18 and up consistently even w/ more city driving. I'm trying shell gas now for a couple tanks to see if that makes a difference, then seafoam before my oil change if the shell fuel makes no difference.
Old 12-31-2011, 11:34 AM
Rep:29
Seafoamed my truck today hoping it would help with my gas mileage since all other maintenance is up to date and it's been down for a good while before the winter blend fuel switch. I put a little over 1/3 into the vacuum slowly letting it pull in at idle and the rest in the gas tank. Started it up 5-6 mins. later and saw a little cloud as I pulled away from the driveway, but nothing more after that for a 15 min drive holding about 3k rpm the whole time. I hope it helps the mpg, I've done fuel injector treatments w/ regane regularly so I don't think the injectors are gummed up.
Old 01-02-2012, 12:30 PM
Rep:4253
If you didn't get much smoke, sounds like you're running pretty clean. Might consider cleaning the throttle body if you haven't already, that really helped my mileage and I did that at the same time as the tune up and air filter replacement.
Old 01-02-2012, 03:04 PM
Rep:29
Yea, it was really just a puff as I pulled away from the driveway that I saw in the mirror, probably just the seafoam burning off. The TB should be good as the last time I pulled and cleaned it there was really not much on it. I guess my next steps are going back to an 87 tune or back to the stock tune, and then maybe swapping out the 180 t-stat for stock if I don't see an improvement.
Old 01-02-2012, 03:09 PM
Rep:4253
Well keep us posted because you've already tried everything I would suggest lol but I'm curious as to why you're not getting what you should and from the sounds of it, you keep your truck as well maintained as I do.
Old 02-06-2012, 06:47 PM
Rep:29
Well, I've reverted back to an 87 tune and my mileage is still sucking. Got a record low today of 15 mpg, I've never seen it that low in the 35k miles I've had the truck. I'm at a loss here, maybe I should change the t-stat back to stock and put in some iridium plugs like I had before. It's gonna take awhile for me to get through another tank since I'm not driving it a whole lot, but if it's low again I'll swap the t-stat and if that doesn't help I'll go back to iridium plugs.
Old 02-07-2012, 06:27 AM
Dancianne's Avatar
Dancianne Dancianne is offline
Vehicle: 2011 Dodge Ram, Quad Cab
Trim Level: ST with combo packag
Rep:136
Dancianne will become famous soon enoughDancianne will become famous soon enough
How about the simpler stuff then? Tire pressure at 40 psi cold, correct wheel alignment, 5w20 oil, changed tire sizes or had brake work done recently? Plug wires still good, or even traveling a different route now?
Old 02-07-2012, 12:45 PM
Rep:29
Wheel alignment is fine as far as I can tell from tire wear and handling. The tire pressure is checked regularly, oil is correct 5w-30 for my 04, brakes are still stock, plug coils should be fine no codes/misfires, and the route is pretty much what it has always been.
Tune Up = Worse Gas Mileage? gain11 5.7L (345 cu in) HEMI V8 Specific Topics 19 01-13-2012 01:13 PM
Fuel mileage Redlongbed Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 11 09-11-2011 10:40 PM
Inexplicable gas mileage ! Crusty128 5.7L V8 Specific Topics 12 03-11-2011 02:45 AM
2003 3/4 Ton V-10 Is this the right truck for me??? ltrpilot LD RAM - General Discussion 6 03-25-2010 10:19 PM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 11:50 AM
