Old 03-15-2011, 11:25 AM
H2OJoe H2OJoe is offline
Vehicle: 1999 Dodge Ram
Color: Green
H2OJoe is on a distinguished road
Default Trans fluid
1999 ram 1500 5.9 auto 107000 miles. I got my oil changed at the local valvoline shop and I saw the "tech" top off the trans fluid. I asked him what kindof fluid it was he said dextron ATF. I know the trans takes ATF+4. Will the half a quart of dextron damage the tranny? Should I dump and flush it? Thank you in advance for your help.
Old 03-15-2011, 11:31 AM
Resident Technician
Rep:1915
Your trans originally called for ATF+3 but the +4 is backward compatible since +3 is no longer sold. The Chrysler manual specifically states:
Dexron II fluid IS NOT recommended. Clutch chatter can result from the use of improper fluid.
While this small amount of Dexron may not hurt anything, I personally would make the quick lube shop pay for a complete flush.
Trans rebuild 94ram1500 5.2L V8 Specific Topics 4 04-07-2011 09:49 PM
Newbie here! 04 HEMI trans fluid smells burnt 04HEMIpower LD RAM - General Discussion 1 02-27-2011 06:43 PM
Low Trans Fluid Burkdadhemi LD RAM - General Discussion 2 01-08-2011 09:21 PM
Trans Fluid Pressure Low code Rapidity 2010 Dodge Ram Forum 1 12-19-2010 01:12 AM
trans fluid an filter change or not? dirty97ram 5.2L V8 Specific Topics 8 08-31-2010 12:10 AM
