Old 03-15-2011, 11:50 AM
08ramKING's Avatar
08ramKING 08ramKING is offline
Vehicle: 2008 dodge ram 1500
Trim Level: leather
08ramKING is on a distinguished road
Question wheel spacer needed with 37" tires???
Okay so I'm in the process of buying a 6" procomp lift+3" body lift and I wantesd to run 37" tires on a 22" rim, I don't think the pro comp lift comes with a wheel spacer but is it needed even with a lift? And if so what size and how??? Thanks!!!! -Charlie
Old 03-15-2011, 12:04 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
What is the offset on your 22" wheels?
Dillon-aka, The Little Kid
Old 03-15-2011, 12:13 PM
08ramKING's Avatar
Trim Level: leather
44mm Offset (4.77" backspacing)
Old 03-16-2011, 07:30 PM
ScatPak07's Avatar
Rep:970
Oh wow so you have a positive offset?? Ya you will need a big spacer. The stock 20s are a 20mm offset so your actually bringing them closer to the truck. I would have to say a 1" spacer is going to be needed, maybe more. You really have to see when you get the tires mounted on the truck. Check how much room you have between the suspension and the tires sidewall.
Old 03-16-2011, 07:35 PM
Not to mention that the section width of your tires will also make a difference in how big the spacer is.
44mm offset??? whoa.....
Old 03-17-2011, 03:38 AM
1badram's Avatar
1badram 1badram is offline
Vehicle: 2009 dodge ram 1500
Trim Level: Bighorn
Rep:22
1badram is on a distinguished road
first off how wide of 37 do you plan on running?
2009 Dodge Ram 1500 SLT Bighorn 4x4 5.7l hemi
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Tires for 2500, need advice Raynval Dodge Ram Wheels And Tires 4 02-02-2010 06:23 PM
17" wheels off for new dodge. DODGE4x4 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 11-25-2009 02:28 AM
Wheel Choices - Get Your Vote On! erm Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 33 11-12-2009 03:56 PM
Wheel spacer question.... Thirstyhemi Dodge Ram Wheels And Tires 11 08-03-2009 12:38 AM
