Old 03-15-2011, 01:22 PM
08ramKING's Avatar
08ramKING 08ramKING is offline
Vehicle: 2008 dodge ram 1500
Trim Level: leather
08ramKING is on a distinguished road
Question are gears needed for a 9" lift???
okay so i have a 2008 ram 1500 ill be getting a 6'' lift+3"body lift and 37r22 tires. Some people have said to use 4.53 or 4.88 gears but then some say i dont need gears yet, see how it drives without them and if needed add them. I need some clarification LOL...Thanks
Old 03-15-2011, 01:33 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
Not so much the lift than the tire diameter you are going to run under it.
4.56's would prob' be your highest (lowest) option for your 4WD.
Drive it once its on so you can get your own perspective if it needs it or not. Only you can tell
Old 03-15-2011, 03:52 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
A lot of other factors will play into this. Is your truck a manual or an automatic? Are you planning to offroad your truck, or just do it for the looks? Do you care if your speedometer is off or not?
You can get by with higher gears in my experience, with an automatic. If your gears are too high with a manual, you can sometimes burn through clutches, because you have to slip them to get the truck rolling. All that is for street driving, which is my guess since you are running 22" rims.
If you plan to off road your truck, then I would definitely opt for the 4:56's. It will allow you to utilize the power band much better than if you left the stock gears in there.
You don't "have" to do anything, but these would be my suggestions.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 03-15-2011, 04:10 PM
I'm betting you will want at least 4.56's as the truck will feel really sluggish to you with the stock set.
Give it a try with the stock set (what do you have, anyway?) but I think you'll notice right away you need a better torque multiplier set of gears.
Old 03-15-2011, 04:30 PM
96RAMMAN's Avatar
96RAMMAN 96RAMMAN is offline
Vehicle: 1996 Dodge Ram 1500 SLT
Trim Level: SLT Laramie
Color: Green+Silver
Rep:13
96RAMMAN is on a distinguished road
I would go with gears anyways if not you'll see a huge drop in gas mileage and power plus you also have to consider the extre weight from 22" rims on top of the 37" meats. I think you could potentially get away without gears, but you could also potentially notice a lot more wear on parts as everything is working a lot harder to spin that tire especially if its a daily driver. Overall if it where me Id save yourself the head-ache and just bite the bullet and buy the gears the first time around.
1996 DODGE RAM 1500 SLT LARAMIE CLUB CAB SHORT BOX 4X4, 360 MAGNUM V8, PIONEER CD PLAYER
Old 03-16-2011, 09:20 AM
DVSk8er DVSk8er is offline
Vehicle: 2010 Dodoge Ram 1500
Color: Inferno Red
DVSk8er is on a distinguished road
go with 4.56's i just put them in my truck and it is a lot better
Old 03-16-2011, 08:22 PM
ScatPak07's Avatar
Rep:970
Yea you cannot go with the 4.88s since they do not make them for the front axle. You will only have the rear but you cannot do that. I think the 4.56s would be a good thing to do so the truck will still run well and have the pick up like stock.
Old 03-16-2011, 08:38 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Another vote for 4.56!!!!!
Old 03-17-2011, 12:13 AM
jackedupdodgeman jackedupdodgeman is offline
Vehicle: 1999 dodge ram 1500
Color: maroon
jackedupdodgeman is on a distinguished road
Default should I change gears?
99 dodge ram 5.5" lift with 315/75's should i change my 3:55 gears?
Old 03-17-2011, 01:04 AM
96RAMMAN's Avatar
Color: Green+Silver
Rep:13
Is it an automatic? If so and you want the transmission to last yes I would say you would want around 4.10 gears.
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 10:49 PM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 11:25 PM
3.55 or 3.92 Gears? Want 35's and lift.. LUCK Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 20 12-15-2010 06:12 PM
Any problems clearing 39.5/13.5 Iroks w/ 9" of lift? MoparerNocar Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 03-01-2010 09:12 PM
How much lift needed for.. Floridaboy92 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 02-03-2010 02:13 PM
