What are the biggest tires that I can put on with a 3in lift/leveling kit? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 04-03-2011, 08:09 PM
boblongtv boblongtv is offline
Vehicle: 2007 Dodge Ram
boblongtv is on a distinguished road
Default What are the biggest tires that I can put on with a 3in lift/leveling kit?
Will 33x12.50s r20 fit with a three inch leveling kit?
Old 04-03-2011, 11:07 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Thats the recomended max tire size with most leveling kit. What kind of leveling kit are you looking at and did you measure to see if you need 3" to level? Most leveling kits are 2" or 2.5"
Old 04-03-2011, 11:25 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Should be more than fine! The 4th gen trucks fit 35" tires with just a level kit
Old 04-03-2011, 11:26 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
You will be able to fit that size tire.
Dillon-aka, The Little Kid
Rep:1338
Originally Posted by 916Timmy View Post
Should be more than fine! The 4th gen trucks fit 35" tires with just a level kit*and wheel spacers or aftermarket wheels*
I fixed it for you Timmy.
Old 04-08-2011, 10:49 PM
ScatPak07's Avatar
Rep:970
There is no such thing as a 3" leveling kit. That would make the front higher then the rear. The only thing that would be 3" is a body lift. With a 3" lift (not level) I would say something close to 35" like a 305/60/20 or even just a 35" tire. When I say lift I mean front and rear. When you do just a leveling kit you should go with a 33" tire to avoid any rubbing.
Also when looking at tires you have to watch the width you go with. When you go higher then 12" you are going to be runing really close or rubbing on the suspension. You will either need to get your self a set of rims with a negative offset to bring the tires out, or a set of wheel spacers. If you go with a leveling kit then you could fit a set of 305/55/20 tires which would be a little taller then 33" and the width would be good to avoid any rubbing. That is what I had when I had a 2" lift (front and rear) and they worked great.
Official Off-Road tire thread!!!! RamCountry Dodge Ram 4x4 - Offroad Discussion 111 10-31-2017 02:54 PM
Levelling Kit? Biggest Tires? Junior Dodge Ram 4x4 - Offroad Discussion 6 03-21-2011 09:06 PM
pics of biggest tires available on stock 4x4? donn12 Dodge Ram Wheels And Tires 5 01-07-2011 02:32 PM
Biggest tires I can fit?! tburton101 Dodge Ram Wheels And Tires 3 02-21-2010 04:19 PM
Biggest Tires on stock '04 1500 Ram Eng0270 Dodge Ram Wheels And Tires 1 10-15-2009 11:57 PM
