Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > Dodge Ram 4x4 - Offroad Discussion
Old 03-17-2011, 08:39 PM
ScatPak07's Avatar
Rep:970
Originally Posted by jackedupdodgeman View Post
99 dodge ram 5.5" lift with 315/75's should i change my 3:55 gears?
Yea the 315/75 means nothing without the rim size. I would guess it is a 17" rim though. You should be alright but you can always upgrade it you feel like the tires are bringing the performance down.
Old 03-22-2011, 10:48 PM
08ramKING's Avatar
08ramKING 08ramKING is offline
Vehicle: 2008 dodge ram 1500
Trim Level: leather
08ramKING is on a distinguished road
Okay 4.56's win!!! thanks for the help everybody, ill let you know how it goes when i got them in
Old 04-01-2011, 10:51 PM
Leadchunker's Avatar
Leadchunker Leadchunker is offline
Vehicle: 1996 Dodge Ram 1500 4x4,
Color: Green
Rep:57
Leadchunker will become famous soon enough
Here is a good link to check out http://4lo.com/ . It had the calculators to figure out the gear ratio that will work best with your wheel and tire combination.
Chuck
Lawrenceville, GA.
Old 04-09-2011, 03:18 PM
ttontis's Avatar
ttontis ttontis is offline
Vehicle: 2010 Dodge Ram 2500
Trim Level: TRX Crew
ttontis is on a distinguished road
I am guessing with the body lift and suspension you plan on putting some pretty big meat under your truck. If that’s true your 1/2 ton axles will not be able to handle it during some serious off roading. Save yourself the trouble and upgrade them to 3/4 ton axles. Also if you change the gears out on the back you have to change the ones up front because your back gears will over power the front and then you could be in for some serious issues. If you do the axel swap you should have a problem getting matched gears with the gearing you want.
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 09:49 PM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 11:25 PM
3.55 or 3.92 Gears? Want 35's and lift.. LUCK Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 20 12-15-2010 06:12 PM
Any problems clearing 39.5/13.5 Iroks w/ 9" of lift? MoparerNocar Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 03-01-2010 09:12 PM
How much lift needed for.. Floridaboy92 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 02-03-2010 02:13 PM
