Dodge Ram Decals
Old 03-15-2011, 02:11 PM
alfonso318's Avatar
alfonso318 alfonso318 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: 1500 (5.9L)gas
Rep:42
alfonso318 is on a distinguished road
Default Seafoam First Time
So i'm planning on seafoamin the Ram for the first time...never done it before and it seems really easy but i'm not sure what hose to hook it up too...? Sounds like half thru the brake boost hose and half in the tank...let sit and then let her rip...anyone have a pic of which hose that would be on a 2001 Dodge Ram 1500? Thanks
Should i dump the stuff into the oil? I've heard that's good but that you need to change the oil shortly after...
Old 03-15-2011, 06:47 PM
greasemonkey's Avatar
greasemonkey greasemonkey is offline
Vehicle: 1998 dodge ram
Trim Level: laramie
Color: white/gray
greasemonkey is on a distinguished road
i like the seafoam it works and if you want to put some in the intake there is a port on drivers side of intake below throttle body take off cap and hook up hose it will draw it in there dont over do it to much of a good thing can be bad but it does work
Old 03-17-2011, 08:31 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
just take the hose off your brake booster thats on the check valve and while its running keep pouring a little big at a time dont just dump half in all at once youll deffinately kill it. after thats said and done put the rest in atleast a half a tank or more and let errrrrr rip.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 03-17-2011, 08:35 AM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
Make sure you get a funnel. And pour real slow. You'll kill it at least once. I need to run some through mine, I haven't in a while.
Old 04-30-2011, 07:12 PM
Mopartruckin Mopartruckin is offline
Trim Level: Sport Off-Road
Mopartruckin is on a distinguished road
I gotta tell ya guys, Seafoam is the beez kneez. I just ran some through my truck using the break booster vaccum line and then soaking the TB and squirting the stuff deep into the manifold, smoked like an SOB but it made all the difference and cured my idle problems (atleast for now). I highly recommend it.
Old 05-02-2011, 12:19 PM
98redbull2's Avatar
Rep:52
Thats good man glad to hear theres another beleiver. now guys theres another thing for transmissions called Trans-X in a blue and black bottle with the picture of a transmission on it but it looks and smells just like sea foam. I used it in my transmission and great results i recommend it if you either have a high mileage or symptoms of wear and tear on urs. within the first 15 mins i poured it in i noticed that it had tighter shifts and the rpms didnt jump as much when u take off from a dead stop. overall great product. i recommend u try it if u ever need too.
Old 05-05-2011, 07:39 AM
teamarctic14 teamarctic14 is offline
Vehicle: 1999 dodge ram 2500
Color: green
teamarctic14 is on a distinguished road
with that trans x do you just pour it in or does it take place of a quart of tranny fluid
Old 05-05-2011, 07:50 AM
98redbull2's Avatar
Rep:52
you pour it in even if the tranny fluid is full, or half no matter what the level is.
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
if you put sea foam in the oil i think it says to change it with in 100 miles
Old 05-05-2011, 08:12 AM
98redbull2's Avatar
Rep:52
yup it turns the oil really thin mixes right in with the oil so you can run it for 5 miles n change it or 100 n change it probably depending on how bad of buildup the engine has in it.
Setting up a time for tints ScatPak07 Dodge Ram Forum CANADA 7 09-06-2010 04:02 PM
Maybe i'll have some time for my ram flacrkr1ton Off Topic Discussion 5 06-30-2010 08:42 PM
Its finally time.... Casualdreamer Military 10 06-30-2010 04:48 PM
First time truck owner, first time dodge owner. user zero Newbie Checkin! 12 11-12-2009 06:02 PM
First time caller long time listener Aves Newbie Checkin! 7 09-26-2008 01:55 PM
