Old 03-15-2011, 04:20 PM
96RAMMAN's Avatar
96RAMMAN 96RAMMAN is offline
Vehicle: 1996 Dodge Ram 1500 SLT
Trim Level: SLT Laramie
Color: Green+Silver
Rep:13
96RAMMAN is on a distinguished road
Default 1996 dodge ram front axle
I like to do a bit of offroading and I was looking at ways to strengthen my front and rear end without swapping to 1-tons (I like to be the odd guy out who does stuff a little differently). I may be getting a used 8" lift for cheap and if I can Im going with 36-37" tall tires, but if I cant get the lift Im possibly looking to go 35-36" tires. So far what I have found that can be done to the front end (witch is what Im most worried about) is this:
Auburn Positraction
yukon ring and pinion gears
and other items U-joints .ect and this:
http://www.emsoffroad.com/store/inde...d49781b9229264
I know most cant truly answer but even with running this when running 35-37" tires offroad would i just be fighting a losing battle? As I realize its still only a half ton dana 44 front end?
1996 DODGE RAM 1500 SLT LARAMIE CLUB CAB SHORT BOX 4X4, 360 MAGNUM V8, PIONEER CD PLAYER
Old 03-15-2011, 04:22 PM
Rep:1845
Posi in the front diff is a bad idea. A selectable locker is what you need.
Old 03-15-2011, 04:33 PM
96RAMMAN's Avatar
Color: Green+Silver
Rep:13
If not a posi then would you suggest like an ox locker, or E-locker, or like an ARB something along the lines of those instead? Also to add to my first post Im not sure if I want to go manual hubs but someone put the idea in my head and I have been throwing around the idea of doing that.
Slight leak in front axle RichJHU 2010 Dodge Ram Forum 6 03-15-2011 06:54 PM
Front axle track bar 06 1500 sport sullivan Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 4 02-17-2011 06:27 PM
Front Axle Replacement Leadchunker Dodge Ram 4x4 - Offroad Discussion 4 01-21-2011 11:23 PM
Rear end confusion dirtsurferus Suspension 6 12-30-2009 09:25 AM
What is a 205MM Heavy Duty Front Axle? oilman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 12-23-2009 03:03 PM
