Old 03-15-2011, 05:15 PM
Tom68 Tom68 is offline
Rep:42
Tom68 is on a distinguished road
Default Front Bumper
Anyone know how easy it is to replace the front bumper?
Mine got dinged up and I'm guessing the part is probably less than my deductible.
I'm thinking of replacing it myself. Seems like it should be fairly easy.
Anybody actually done it?
Old 03-15-2011, 07:50 PM
I haven't done your model truck specifically but most of them are pretty much the same. You have a bracket bolted to the frame ends and this bracket has two extensions that go to the bumper.
If you have a urethane section, that bolts to the top of the metal portion of the bumper and the bottom of a horizontal piece that runs to either side of the truck below the grille.
I'd suggest you get a service manual for your truck (usually available on CD in a .pdf format online - I got mine on eBay for $10) because the exploded view drawings, diassembly and reassembly info is priceless.
Not much is needed in the way of mechanical skills but some knowledge of how the assembly is attached to the truck is a definite plus.
Front Bumper Fascia,Grill, & Bumper Removal Write Up moparornocar72 Dodge Ram Knowledge Base 11 09-21-2014 09:40 AM
2006 vibration 55mph rake1 Suspension 41 03-07-2014 08:52 PM
n-fab Full Replacement R.S.P. Front Bumper kush and a 40oz 2009 Dodge Ram Forum 6 01-21-2011 07:35 PM
Bad Front Bumper Fascia Replacement/Repair BigEmpty Body & Interior 21 12-01-2010 07:40 PM
Front Bumper R&R 09silverbighorn Body & Interior 4 10-26-2009 11:17 AM
