Old 03-15-2011, 07:19 PM
cmatt4775 cmatt4775 is offline
Vehicle: 2010 Dodge Ram SLT
cmatt4775 is on a distinguished road
Default Mirrors with Turn Signal
Does any one know if you buy the mirrors that have turn signal and you only have standard with out it can you install the upgraded ones.
Old 03-15-2011, 07:22 PM
I'd pull one of your mirrors and look for the wiring harness.
Old 03-16-2011, 01:12 AM
ramfan1500 ramfan1500 is offline
Vehicle: 2010 dodge ram 1500
Trim Level: trx
Rep:63
ramfan1500 will become famous soon enough
I did this and can say without a doubt that it does not work. I installed the upgraded mirrors and then took the truck to my dealer to have them flash the evic so that they would turn on. dealer was unable to make them work, so save your money.
Old 03-16-2011, 05:16 PM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Rep:48
Hotfingrs is on a distinguished road
Ditto on above, can't be done...
Old 03-16-2011, 05:25 PM
So the turn signal wiring is not part of the harness that is already there, huh? That sucks....
Muth, an aftermarket maker, might have a set of mirrors with the harness adapter. They are the primary supplier to most of the OEM's.
Problems with my turn signal lights. kjtc6 Electrical 20 06-06-2013 08:02 PM
Open Door Tone/Burnt Out Turn Signal Bulb?! thedvsmonkey Electrical 15 03-31-2012 11:31 AM
Trailer turn signal not working EBK142 Electrical 10 03-19-2012 07:52 PM
Turn signal acting off jayhkr Electrical 5 07-29-2011 03:59 PM
ST upgrade to turn signal mirrors? Chinchilla 2010 Dodge Ram Forum 7 12-28-2010 12:45 AM
