Old 03-16-2011, 06:00 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Thats cool info thanks! I get it totally now. After visualizing the tires being the same height and changing the rear gears out the rpms change not the mph's.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 03-16-2011, 06:41 PM
I push the skinny pedal
Rep:3277
Glad I could help I know, everyone always just says: "change gears to bigger" and everybody wants 'bigger' gears, but you need to look at what you want out of them and why you want to do the swap.
For the OP, the reason his vehicle's speedo changed with gears was his vehicle took the speed measurement from a point BEFORE the rear diff, so in that case it would cause a change. Just not in the case of our trucks which take it from a location after the gears.
Kurtis
Old 03-16-2011, 07:23 PM
Red05Ram Red05Ram is offline
Vehicle: 2005 Dodge Ram 4x4
Color: RED<----
Rep:15
Red05Ram is on a distinguished road
Good info thanks, ya I wanna go 35's and my gears are long enough all ready, good to know my mph will stay the same thanks
K&N FIPK,Diablo Custom tune,TTI Long Tubes,True Dual 2 1/2 inch, Borla XR1 Mufflers,4.56 gears,Jet 180 stat, Fastman TB, Cam Swap
Old 03-16-2011, 10:07 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
the tone ring for the speed-o is in the rear axle...has been since '98 IIRC. if you swap gears your speed-o will still read accurate. no changes needed.
like others stated you will need to recalibrate your speed-o with a different tire size.
Old 03-17-2011, 12:22 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Did some serious digging, and ..... You are 100% correct!
I stand corrected...
As it turns out, you can go gear happy in your Ram, and not affect the speedo, but a tire size change will affect it.
Thanks to all for bringing this tidbit of information out in the open. Having not done a gear change in any of my newer Rams, I assumed it was still taking the speedo information from back of the trans. WTG Dodge! AND WTG Ram ForumZ!
brad
Interested in one of my mods?
Speedometer Calibration Cap10crch Electrical 7 11-14-2010 11:24 AM
Gear Swap 04HemiRam Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 03-14-2010 10:27 PM
Gear swap J1M Dodge Ram General Discussion 0 08-23-2009 01:47 AM
Gear swap J1M Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6 0 08-23-2009 01:40 AM
Rear end gear swap?? ScatPackRam Dodge Ram General Discussion 6 08-04-2009 08:08 PM
