Old 03-16-2011, 12:41 AM
Leviathan Leviathan is offline
Vehicle: 2010 Ram
Color: Brillant Black/Silver
Leviathan is on a distinguished road
Thumbs up Installed MyGig Lockpick today
I installed a Mygig Lockpick today. For those of you in the market for one, this is a pretty nifty little device. Completely plug and play, and very simple to install. They included plenty of extra wire; I was able to velcro mine inside the dash behind the steering wheel. If I ever need to remove it or update the firmware it will be easy to reach.
I also installed a front camera. That was slightly more complicated than the Lockpick but not bad. A couple of notes for those who are considering doing this.
1. If you have the factory backup camera you will need to run new power to it.
2. The installation instructions say that new power is only necessary if you want to view it when not in reverse. That may be technically true, but my front camera did not seem to work correctly until I ran power from the lockpick to the rear camera
3. In the instructions Lockpick advises to find the power to the rear camera and replace it with power from the lockpick. The instructions for that portion were incorrect. They say to test the wires and the one that only has power in reverse is the correct one, but my camera power was constantly on. It still interfered with my front camera; I assume because it wasn't being controlled by the Lockpick. BTW, my backup camera power was the red one. I'm never sure, but in this case convention prevailed.
Anyway, I am stoked for this mod. It is the first big one for the new truck.
5% Tint, MyGig Lockpick, Front Camera, BedRug, Shorty Antenna, A.R.E. CX Truck Cap.
Old 03-16-2011, 01:00 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Sounds like a great mod. I have the Lockpick for mine, but haven't installed it yet...waiting for some nicer weather.
Which camera did you get for the front? How/where did you mount it? Do you have any pix?
brad
Interested in one of my mods?
Old 03-16-2011, 01:05 AM
ramfan1500 ramfan1500 is offline
Vehicle: 2010 dodge ram 1500
Trim Level: trx
Rep:63
ramfan1500 will become famous soon enough
I bought one and was bummed when I learned I would have to cut my factory wiring to allow veiwing of my factory cam in drive. There is no mention of this in there ads
Old 03-17-2011, 06:25 AM
BigJim1500's Avatar
BigJim1500 BigJim1500 is offline
Color: Deep Water Blue Pearlcoat
Rep:59
BigJim1500 will become famous soon enough
I installed my lockpick without cutting any wires or running power to the rear camera and it works just fine. Just plugged it in. I can toggle the view of the rear camera on/off at any time while in drive. I did not install a front camera if that is the difference.
[B][COLOR="Blue"][U]BigJim1500[/U]:[/COLOR][/B] 2010 1500 Laramie CC, BLUE, Mopar Tonneau, Short Black Antenna, Lockpick, Pinnacle 50% Tint (all around), K&N Drop-in, Cat-Back in the Spring
Old 03-17-2011, 11:51 PM
Vehicle: 2010 Ram
That makes sense, because the rear camera always has power to it. You should be able to see it in drive. Again, the lockpick instructions were incorrect on that point. That could also be why it interferes with the front camera, they are both on at the same time without the power coming through the lockpick. We just solved a mystery! Yay!
Old 03-18-2011, 08:46 PM
Trim Level: trx
Rep:63
HEY BIGJIM1500, did you have a factory rear cam or did you install a rear cam. My instructions state that if you already have a factory rear cam then you must cut the factory rear wire because it gets its power via the backup lights which only come on in reverse. When in drive there would be no power. If you installed a rear cam on your truck there would not be a factory wire to cut. I have not cut my wire yet so I can not view my cam in drive. Other than that I really like my lockpick. Looking forward to hearing your answer because if you had a factory cam already on your truck and yours is working without any cutting of factory wires, then I may have something wrong with my lockpick
Old 03-19-2011, 01:05 AM
Vehicle: 2010 Ram
My factory backup cam had constant power, both in reverse and not.
Old 03-19-2011, 08:28 AM
rlandon's Avatar
rlandon rlandon is offline
Vehicle: 2010 Dodge Ram Crew Cab 2WD
rlandon is on a distinguished road
Now that you have the lockpick, go get a Artec digital TV converter and a flat TV antenna and enjoy free local TV on your MyGig. If you want more details just ask or PM. I've done this to my Nitro R/T and Ram. The reason I suggest the Artec is the small size of the unit.
Previous Rams: 1954 C1-B6 Rodded, 1976 D100, 1994 RC, 1998 Supercharged EC, 2003 QC R/T Custom.
Old 03-19-2011, 11:25 PM
Vehicle: 2010 Ram
Do you get decent reception while moving, or just when sitting still?
Old 03-20-2011, 11:40 PM
rlandon's Avatar
Living here in Podunkville near the coast our transmitters are far away (due to hurricanes). Reception is good only when sitting still. When I'm in large cities, it works while driving.
camera, lockpick, mygig, navigation, video
Installed projectors and HID's today. angshan Custom Dodge Ram Interior and Exterior Lighting 110 05-09-2011 11:09 AM
NEXT MOD! Installed nerf Bars on my 2011 Quad Cab Ram Today uncletony76 2011 Dodge Ram Forum 16 03-20-2011 12:12 AM
Mygig lockpick v.3 BigJim1500 2010 Dodge Ram Forum 17 03-14-2011 12:33 AM
Installed mygig and its broke 2010DodgeRamSport 2010 Dodge Ram Forum 9 02-26-2011 10:46 PM
Installed a K&N today and you dont want it waldig 2009 Dodge Ram Forum 39 09-28-2010 12:27 AM
