Old 03-16-2011, 11:04 AM
kardys35 kardys35 is offline
Trim Level: Sport CC
kardys35 is on a distinguished road
Default Brake Controller Flash
I just got from local dealership after trying to have them flash cpu for the brake controller and they said there was no update for it after they hooked in to cpu. From what I have read the dealerships should be able to flash cpu so the brake controller is recognized or am I wrong???
Old 03-16-2011, 11:06 AM
RamTech RamTech is online now
Rep:1885
What your talking about isn't a flash. What they do is update the build configuration with Chrysler and then upload that new configuration into the TIPMCGW.
Old 03-16-2011, 11:17 AM
ok....not sure what that means. To make it easier what do i need to tell the dealership so I can have the brake controller to work with the evic display?
Old 03-16-2011, 11:22 AM
Rep:1885
Tell them you added the controller and you need the build configuration updated.
Old 03-16-2011, 11:23 AM
ok thank you..I will try and see what happens
2010 Ram Factory Trailer Brake Controller Install Netman66 Dodge Ram Knowledge Base 334 04-17-2014 01:51 PM
OEM brake controller flash Jgroes 5.7L (345 cu in) HEMI V8 Specific Topics 1 10-14-2010 11:48 AM
Adding a electric brake controller dave k Electrical 3 08-06-2010 10:36 AM
Installing Tekonsha Brake Controller - No Power mullinon 2010 Dodge Ram Forum 6 07-15-2010 01:04 PM
led third brake light/brake controller pa03hemi Custom Dodge Ram Interior and Exterior Lighting 3 05-20-2010 03:26 PM
