Old 03-16-2011, 12:35 PM
Kpass3490 Kpass3490 is offline
Vehicle: 1998
Trim Level: Laramie SLT
Color: Green
Kpass3490 is on a distinguished road
Default Aftermarket stereo
My friend and I just hooked up my new Pioneer flip out touch screen DVD head unit last night, and he did most of it since he had some training and has done many others. After we finished and put it all back together we learned it doesn't work right. When you go above around six on the volume it just gets a bunch of static and you can't here, it does this on all of the input settings. Any ideas?
Old 03-16-2011, 12:42 PM
Get Bit's Avatar
Get Bit Get Bit is offline
Vehicle: 2004 Dodge Ram RC 4x4
Trim Level: SLT Sport
Rep:71
Get Bit will become famous soon enough
Did you use a wiring harness which is correct for the truck and deck, or did you just splice into everything?
Static could be interference caused by bad ground, insufficient power, swapped +/- speaker wires, etc.
Old 03-16-2011, 01:07 PM
Vehicle: 1998
Color: Green
Yes I used a wiring harness that is specific to my truck but the truck itself has no ground wire so we have to find somewhere else to put the one from the head unit and aren't getting any good places there's not much metal in the dash either.
Old 03-16-2011, 01:17 PM
I push the skinny pedal
Rep:3308
It does sound like a bad ground to me as well, you could ground the radio chassis to the frame and see if it helps.
Kurtis
Old 03-16-2011, 01:42 PM
Get Bit's Avatar
Rep:71
Bad ground would do this, easily. Run a new ground out into the engine bay through a gromet and find a place on the frame to ground it too. You might also find a common grounding area that other things are grounded to.
Or run one down under your carpet and ground it using one of the bolts on the seats. Just use good washers and have the connector between them or something.
Old 03-16-2011, 02:56 PM
Vehicle: 1998
Color: Green
Finally got it right, thanks guys
Old 03-16-2011, 10:17 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Rep:55
Ram15002ndgen will become famous soon enough
What do you mean there isn't much metal in the dash? The entire dash is held in place by a metal frame. All you have to do is tie into any of the screws that hold the panels to the metal frame. Maybe all you need is a little sand paper to clean the metal to ground it to. After years of accumulation of grime, the metal contact may not be very conductive. You are obviously getting ground or the unit would not work.
www.beatcraigslist.com - for posting dangers & secrets
Old 03-16-2011, 10:29 PM
Get Bit's Avatar
Rep:71
Not true, you can have a bad ground which is insufficient and it will cause interference. Electronics are touchy and not always black and white or working or not.
Old 03-17-2011, 12:08 PM
Vehicle: 1998
Color: Green
Yeah there was the metal in there but he would have to drill into it and couldn't get his drill in there so he just ran it through the dash and finally used an area under the steering column that had a place with screw to metal to hold it.
just put a new aftermarket stereo into my 98 ram.... 2 front speakers not working? newrammer88 Custom Dodge Ram Interior Modifications - Custom Audio / Video 5 06-05-2015 02:15 AM
Aftermarket stereo Guinnessboy 2010 Dodge Ram Forum 3 02-09-2011 01:15 AM
2006 Dodge Ram 1500 aftermarket stereo. Questions Jesse94 Custom Dodge Ram Interior Modifications - Custom Audio / Video 5 12-14-2010 11:50 PM
Stereo switch with an aftermarket stereo jcasey10 Electrical 4 05-03-2010 10:47 AM
Having problems with an aftermarket stereo! teabbey Electrical 1 02-14-2010 10:30 PM
