tonneaucovered.com
Old 08-17-2011, 09:45 AM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Here's something interesting on the suject of turbo charging the Hemi. Pay close attention to the aluminum vs the cast heads and blocks. [url]www.lxforums.com/board/.../all-aluminum-turbo-gen-iii-hemi-2568 or google All Aluminum Turbo Gen 111 Hemi?????-Lx Forums|Dodge Charger
Old 08-17-2011, 10:12 AM
Second Life's Avatar
Second Life Second Life is offline
Vehicle: 2011 Ram 1500 Crewcab
Trim Level: Outdoorsman 4x4
Color: Deep cherry red
Second Life is on a distinguished road
The Ecoboost is an aluminium block and Head, too.
Truxedo LoPro - Westin Premier 6'' Oval tubes - Sonnax line pressure booster - Dee Zee rubber bed mat - Magnaflow 12259 - K&N Aircharger - Bilstein 5100 set at 2.8'' - BullyDog GT for Hemi Plus
Old 08-17-2011, 10:28 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
In my opinion ford is not reliable, and I do not like their styling. I also did not like their old engines. The new engines are great though, the new 5.0L and the new ecoboost engine. Don't be fooled because it is a 6 cylinder, it has more torque at any rpm than the HEMI, and alot more at most rpm. It has over 400ftlb between 2,000rpm and 4,000rpm, and over 350ftlb between 1,500rpm and 5,500rpm. That is damn impressive. Assuming all else being equal, the ecoboost is capable of more pulling power....don't know about faster (ie acceleration). Acceleration would be close I'd guess, but trans, gear ratio, weight, etc....plays a big role. I haven't seen a dyno on the new hemi, but would guess it wouldn't have 400ft lb until around 4,000-5,000 rpm, and wouldn't have nearly that wide of a range with 350ft lb.... Still love the HEMI and hate ford just saying it's a remarkable engine...
Apparently it is durable too, independent testing agencies have performed torture tests showing that it will hold up to extreme duty and overheating of the turbos....how it does in the real world who knows...I expect it will be like all other fords, but with some actual power now.
Sean
Old 08-17-2011, 10:44 AM
RadioFlyer's Avatar
Rep:146
I agree, turbos are compared to a deisel when it comes to torque only I don't agree with the extreme testing...it was done by Ford. Google serch complaints from costumers if you really want to hear it from the horses mouth. Also, you mentioned heat...they run so hot that the hood steams like it's on fire when it rains, lol!
Old 08-17-2011, 10:56 AM
snrusnak's Avatar
Rep:1385
I'm not talking about the videos on their site....I've seen a few articles supposedly by independent companies. I don't know much about the ecoboost, but assume it's intercooled and the turbos have some sort of cooling system (oil maybe?)....couldn't see it ever getting extremely hot even when towing, unless it was a "torture test" scenario, like climing to the top of a mountain with 11,000lb as fast as possible...lol
Sean
Old 08-17-2011, 11:20 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Well guys....I finally got the answer I was looking for.
A very good friend of mine purchased a 2011 Eco, and let me take it for a drive when only had about 500miles on it. I was impressed, and stated at the time that I wanted to do a real 'street race' after he enough miles on it to consider it properly broken in. Today was that day. He now has 10K miles on it, and I have 14Kmiles on mine. We have virtually identical rear ratios, and both removed any cargo out of our trucks so ran the race(s) with both trucks in basic stock form, with the same 'full tank' of fuel and no cargo.
Race 1 - 1/4mile standing start - I got an excellent view of his tail lights the entire way.
Race 2 - 1/4mile 30mph start - He saw my tails for a bit, I never saw his, but I did get a good view of his sliding rear window.
Race 3 - 1/4 mile 40mph start - He handed me my butt on a platter (speed limiter is higher on his).
We used only the best high-tech facilities (quiet highway), with state of art racing tree (his buddy with a Strion flashlight), and very accurately measured and marked 1/4 mile (440 paces and Duplicolor white paint).
Reality - The Ford Eco out performed me in all real world street racing....hand down!
Reality 2 - When we decided to go for a simple cruise and a coffee, he wanted to go in my truck. Even he thinks it looks better... LOL.
So....I lost 3 races....but sure looked good doing it.
Did you load the torque converter before take off? That would pull a bit of timming and you would lose some power but im not sure that it would make that much diferrence. Also, if you were 4x4, i would have ran it in 4x4 till i got out of the hole, then put it into 2wd. And if he was 4x4 this might have been what he did to get a launch on you. Not to say that you can drive your truck but it does help to have someone who can make the vehicle run right.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 08-17-2011, 11:30 AM
Ecoboost F150 4x4 are low 14 to mid 14 seconds truck. They are fast.
With good take off (4x4 with brake/boosting)
Old 08-17-2011, 11:38 AM
snrusnak's Avatar
Rep:1385
Very interesting! As much as I don't like ford, I'm glad they are the ones coming up with good products instead of toyota or nissan or honda, etc....
Would hate to see a v6 turbo tundra smoking our american trucks. Ford isn't so bad....but I'll keep my dodge...
You know, you could argue that the v6 turbo is not a "fair" competitor for the hemi, and that the only "fair" competitor would be the 6 cylinder cummins Let's see whose better then
Sean
Old 08-17-2011, 11:45 AM
RadioFlyer's Avatar
Rep:146
All turbos get extemely hot...at medium to high speed, I wouldn't call 950 degrees celsius cool, lol! BTW...the turbos are water cooled Honeywell GT 15's mounted directly to the manifolds...right under the driver and passenger sides feet. Good for winter time though... you won't have to worry about cold feet cause they'll be nice and toasty, lol!
Old 08-17-2011, 11:51 AM
snrusnak's Avatar
Rep:1385
Is it intercooled? Has to be to make that good of power....
Sean
SuperCharged Hemi RAM thanks to Magna Charger azzo540 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 240 11-30-2015 01:19 PM
Free Hemi on Base No Options short cab short bed 2010 1500 cyberpine 2010 Dodge Ram Forum 19 07-21-2011 12:54 AM
