Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Towing
Old 03-16-2011, 02:49 PM
mike56 mike56 is offline
mike56 is on a distinguished road
Default Tow/Haul
2011 Ram 1500 5.7 automatic. When Tow/Haul button is engaged I notice that the transmission shifts at a higher RPM, and a number 5 comes on in the dash. This is the same number that shows what gear the truck is in when the manual shift mode is in use. I know that the transmission does not shift to 5th gear with the Tow/Haul button engaged, but why is the dash telling me the truck is always in 5th gear? I haven't towed my trailer yet, but I am wondering if everything is correct. The number 5 is on even if I am stopped.
The owners manual does not address the Tow/Hual feature execpt to show the location of the Tow/Haul button.
Old 03-16-2011, 03:17 PM
jsims006 jsims006 is offline
Vehicle: 2011 Ram 1500 QC
Trim Level: Big Horn 4x2
jsims006 is on a distinguished road
That number is the 'highest' gear that your vehicle will shift. The tow/haul disables overdrive and raises the shift points... not sure what else it does, but that is all I can physically tell. I believe 5th gear is still active, but I have only used tow/haul at low speeds and off-highway use.
If you set it manually to "4", for example, you won't shift into 5th gear.
Hope this helps, I'm a new RAM owner so I am still learning.
Old 03-16-2011, 05:34 PM
WOOSAB WOOSAB is offline
Vehicle: 2010 Ram 1500
Trim Level: Big Horn Package
Color: Mango Tango
WOOSAB is on a distinguished road
the truck still goes into 5th gear. the shift points are raised to give more torque i believe. I asked the dealer this same question. Because before i bought the truck we had to hook it up to my boat so i could make sure it pulled it smoothly. Mine also readys 5 at all times when in tow haul mode. You can shift to 4 and it will not go past 4th gear.
[IMG]http://i860.photobucket.com/albums/ab166/woosab/Boat/mango-1.jpg[/IMG]
Old 03-16-2011, 06:33 PM
dafoot dafoot is offline
Vehicle: 2011 Dodge Ram, 1500, Hemi
Rep:16
dafoot is on a distinguished road
So you hooked up the boat BEFORE you bought. I should have been that smart! But i did'nt Won't make that mistake again
DAFOOT
Old 03-17-2011, 09:57 AM
Color: Mango Tango
I had a 2001 or 2002 ford f150 and a tahoe i used to pull the boat prior to this. But we started traveling from south GA to lake norris in Tenn well we had to go up and down the mountain ands the f150 and tahoe would struggle up and down the mountains. So i actually pulled up to the dealership with the boat attached to my f150. So on the test drive we hooked it up to the ram and off we went. I figured the only reason i am buying this is to pull the boat so i mise well test it out from the start. I wanted to see would the 1500 pull it ok or did i need to move up to the 2500..The boat makes the truck look tiny. But that hemi does the job! you could tell the difference as soon as i pushed on the gas. It handles better has more torgue off the line and didn't struggle like the ford did.. Me and my father share 2 boats. 1 is for adult time and other little speed boat we use to pull the kids. Well we went and looked together he was so impressed we both ended up buying a ram that day.. I got the orange he got the other..
Old 03-17-2011, 10:37 AM
uktitus uktitus is offline
Vehicle: 2009 dodge Ram 1500 4x4
Trim Level: Laramie crew cab
Color: Grey
Rep:41
uktitus is on a distinguished road
i hope you got a really good deal two for one?
Old 03-17-2011, 12:59 PM
moparmanicac's Avatar
moparmanicac moparmanicac is offline
Find em hot leave em wet
Vehicle: 12 RAM 1500 qc 4x4 HEMI
Trim Level: express
Color: bright silver
Rep:204
moparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura about
Those are 2 nice Rams doing one of the things that they were made to do thanks for the pics
[SIGPIC] RIP 02 4.7 Dakota sport qc 4x4
RIP 05 Ram 4.7 rc 4x4
HELLO 12 Ram HEMI qc 4x4 and 94XJ
Old 03-17-2011, 01:09 PM
Color: Mango Tango
I thought both our trucks had the 3.55 gear ratio... I just requested a build sheet from dodge.com and i was wrong both trucks have
DMH 3.92 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
that personally means nothing to me. I asked on 1 of the other forums what the ratios mean and someone kind of explained it to me. All i took from it was the higher your number the better for towing... If i have that correct. Anyway i love them and they do a great job of towing my toys. The big boat with gear and gas weighs in between 7,500 -8,000 pounds and no problems. But when we take both boats i try to pull the little one let me dad pull the heavier one and pay for more gas LOL...
Also i would like to think they gave us a good deal since we bought 2. We paid 27K and some change each..
Old 03-17-2011, 01:55 PM
Pull Ya's Avatar
Pull Ya Pull Ya is offline
Vehicle: 2013 Dodge Ram Laramie 4x4
Rep:365
Pull Ya is just really nicePull Ya is just really nicePull Ya is just really nicePull Ya is just really nice
If your pulling 7500-8000 with that 1500 I think I would be a little more concerned with stopping instead of with the pulling power of that truck-----IMHO
Jay
Just cause it's loud doesn't mean it's fast and just cause it's shiney doesn't mean it's protected.
Semper Fi Forever
Old 03-17-2011, 02:27 PM
Color: Mango Tango
10,450-pound maximum towing capacity for the regular cab, long-bed, two-wheel-drive model with a 5.7-liter Hemi V-8. It also requires a 3.92 rear axle.. Which is what i have.
http://news.pickuptrucks.com/2009/07...50-pounds.html
i have always gone by as long as you don't tow over 80% of the vehicles maximum towing compacity that should leave plenty ability to stop or for quick manovers. Keeps you in control of what your towing...
grinding noise while tow/haul engaged? Pigpen 2011 Dodge Ram Forum 9 09-06-2011 09:04 PM
Tow/Haul mode or no? SvB4EvA Drag Racing Discussion 11 11-28-2010 03:48 PM
Tow/Haul mode Zeus 2009 Dodge Ram Forum 2 09-18-2010 08:00 PM
Tow/Haul Mode BlueLightning 2010 Dodge Ram Forum 25 08-11-2010 01:40 PM
Tow/Haul should be Cruise/Cool MotorCityRam 2010 Dodge Ram Forum 13 04-02-2010 08:07 PM
