Old 03-16-2011, 02:04 PM
Kpass3490 Kpass3490 is offline
Vehicle: 1998
Trim Level: Laramie SLT
Color: Green
Kpass3490 is on a distinguished road
Default Lifter problem
I have a 98 Ram 2500 2wd gas truck and I have a tapping under the hood that gets louder and faster the more gas I give it, I've been told this was a lifter but get many conflicting answers, any ideas? Also I have put it to the flier just a couple times and it almost sounds like it pops out of gear and.it goes nowhere till I let off and give it less gas, sometimes when I go to take off fast it revs way up and doesn't shift till I let off the gas too.
Old 03-16-2011, 09:13 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Rep:55
Ram15002ndgen will become famous soon enough
Sounds like you have a couple of unrelated problems there. The lifter issue sounds about right. If you know what you are doing you can take off the valve cover and see if anything is loose, if not take it to a shop. The tranny problem sounds like maybe a pressure governor problem. I'm no tranny expert so just take it for what it's worth. Again, take it to a shop that knows more than we do, but shifting weird is certainly a tranny problem.
www.beatcraigslist.com - for posting dangers & secrets
Old 03-17-2011, 11:05 AM
Vehicle: 1998
Color: Green
Thanks, I'll do that
Old 03-17-2011, 12:07 PM
Rep:1890
Check for an exhaust leak at the manifold before you go tearing the valve covers off.
Old 03-17-2011, 09:19 PM
Could be a exhaust leak . But the 5.9's didn't have a real problem with that . If you pull off the valve cover , look for a bent pushord , or even a broken valve spring before condemning a lifter .
Old 03-18-2011, 05:15 PM
Vehicle: 1998
Color: Green
All right I'll try, I just don't know much about working on them myself, so I'll try to find somebody to do it for me.
Old 03-25-2011, 07:55 AM
Vehicle: 1998
Color: Green
I've been told now that it's probably a bearing so I'll have to have it looked at to see what the problem really is I guess.
Old 03-26-2011, 11:06 PM
Can you post up a audio clip for us to hear ? Theres a bit of a difference between a tap and a knock .
Old 03-27-2011, 12:13 PM
Rep:1890
Disabling the affected cylinder will tell you a lot. If it's a rod knock, the noise will change in volume and intensity but a lifter won't change at all.
Transmission Problem 07 Hemi 07Ram 5.7L V8 Specific Topics 14 03-14-2013 06:45 PM
Please Help! Engine Problem mowery33 5.9L V8 Specific Topics 6 01-28-2011 09:49 AM
First Dodge - First Ram - First Post - First Problem koolaidzx2 Newbie Checkin! 11 01-17-2011 12:10 AM
Door Ajar Light & Power Windows Problem. scottdutton Electrical 1 12-05-2010 04:54 PM
Yet another HID problem griffin407c Custom Dodge Ram Interior and Exterior Lighting 10 10-27-2009 04:37 PM
