Old 03-16-2011, 02:09 PM
zach99's Avatar
zach99 zach99 is offline
Vehicle: 2009 Dodge Ram 1500
zach99 is on a distinguished road
Default To much positive camber..?
I installed a 2.5" HBS leveling kit a few months ago and had an alignment done the following day. But since ive installed the leveling kit the tops of my tires tilt out further than the bottom..(to much positve camber?).. Is this adjustable if i brought it back in?? Thanks for any input.
Old 03-16-2011, 02:54 PM
Rep:1885
How much positive camber do you have? A certain amount is within specs and it is adjustable with the cam bolts on the lower control arms. Sounds to me like all you got was a "toe and go" alignment.
Old 03-16-2011, 10:20 PM
HEMILANCER's Avatar
Vehicle: 09 Dodge Ram
Color: deep water blue
Rep:85
positive camber is bad for handling find out what the optimum number is and go a little negative from there.
Too many mods to fit here!
Old 03-16-2011, 10:46 PM
Do you have the alignment sheet from the last alignment ? If so post it up . I'll look at it .
alignment, camber, leveling kit
camber kits?! GregInAtl Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 11 05-24-2013 09:20 AM
2 questions, Camber and body lift. volcom54626 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 22 11-26-2010 09:00 PM
Camber adjustment - How? Thetolleyman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 11-14-2010 05:59 PM
Door Speaker Positive Wire Determination...HELP JaredConspiracy 2010 Dodge Ram Forum 3 11-09-2010 08:46 PM
Adjusting camber Big Red Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 11-09-2009 09:09 PM
