Old 03-16-2011, 04:46 PM
stangallmotor stangallmotor is offline
Vehicle: 2011 RAM R/T
Trim Level: R/T
Rep:60
stangallmotor will become famous soon enough
Default How to remove the front Ram emblem?
Hey Fellas, How do I remove the front Ram emblem on the grill? I have a 2011 Ram R/T. Thanks
Old 03-16-2011, 05:12 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
The search is your friend. Been discussed many times!
[CENTER][SIGPIC][/SIGPIC]
Old 03-16-2011, 05:27 PM
Not sure on your year truck...sorry. Mine was pretty easy. I just uses a small screwdriver (and cushioned the surround area with a rag), lifted the top edge of the emblem and introduced a bit of 3M adhesive remover around the edge. I let it sit for about 10 minutes and then used a hair dryer to warm things up. The emblem peeled right off.
Old 03-16-2011, 05:28 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
It has clips it might be easier to get to if you remove the front grill. It takes me like less and 5 mins to remove it with the right extensions.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 03-16-2011, 05:32 PM
Good idea!!! ^^^^
Old 03-16-2011, 05:45 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
I believe the 4th gens are held on there with clips instead of adhesive.
Dillon-aka, The Little Kid
instructions to enable front seat video in motion partypooper 2010 Dodge Ram Forum 20 08-05-2011 07:14 PM
front license plate? Freightrain Body & Interior 15 03-21-2011 07:52 AM
Replacing Water Pump (Question) How do I remove fan from waterpump pulley MMMMDude 5.9L V8 Specific Topics 6 01-31-2011 03:12 PM
Heating & Cooling grioux Heating & Cooling 3 01-27-2011 12:53 PM
Question about adding Bilstein 5100s (front is sitting lower again) City Slicker Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 17 04-20-2010 11:53 PM
