Old 03-16-2011, 07:23 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
It would be considered 4 wheel then. I'm presuming all they're talking about is the fact that you have a front differential. Not if you drive in 2wd but have 4wd capabilities
Old 03-16-2011, 07:26 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Originally Posted by geddy View Post
This always confused me, actually. My truck is 2WD by default with the option of turning on 4WD/4WDlow. I imagine this still means my truck is considered 4WD since it obviously has the capability?
Yes, you will need to buy a 4WD lift, because the suspension systems are different between the 2WD and 4WD trucks.
Dillon-aka, The Little Kid
Old 03-16-2011, 08:11 PM
geddy geddy is offline
Vehicle: 2009 Dodge Ram SLT Quad-Cab
Rep:13
geddy is on a distinguished road
Alright, awesome guys! Does anyone have any suggestions as to what brand I should look for? I'm really in the dark with this kind of stuff :\ My girlfriend's father is in the auto business and he might be able to help me get in touch with people who I can buy from.. but what kinds of experience do people have with different companies?
Old 03-16-2011, 08:26 PM
KORE Racing, SuperLift, Rancho, Tuff Country, Rough Country are all good firms.
I would be prepared to read each mfgr's offerings carefully to, 1) determine what parts are included, and, 2) the lift method (springs, blocks, etc...)
One other thing you will want is a steering stabilizer assembly for the front so if any of those kits have one included that's a bonus. But most mfgr's list those separately. Just make sure you get one.
Old 03-16-2011, 08:43 PM
ScatPak07's Avatar
Rep:970
If you want to g with a lift then dont cheap out. Rough Country does make cheap kits and you can tell once it is on...even with the written instructions being garbage. You should look at Rancho, Superlift, Zone or BDS. Those are really good kits and you will be happy spending a little more for better quality. If you want to go a little cheaper thn the Zone kit would be good since they are the same as BDS.... the two companies have history togethre. I always have the motto you get what you pay for, and my trucks suspension is not one I would want to cheap out on. As Maddog said KORE and Superlift are other really good companies. I know he put Rough and Tough Country but I just have heard crappy things so...... ANYWAYS!
All the kits come with everything you need to complete the lift kit. You can always do some add ons like steering stabilizers (if made by the company you choose and for your truck), sway bars and ladder bars. Those will help out you control of the truck and make the suspension better.
I would highly recommend waiting to put the lift on until you get the tires on. The truck will look kinda goofy without the tires on. You should look at a 35" tire to make it look really good.
With the gear comment you should check out what you have now. You can check that by looking at the rear axle, it is located on the front of it on the passenger side. It is on a little rectangle tag on the axle itself. If you have a 3.92 gear in it already then you will not need to upgrade the gears since they can handle that big of a tire. If you have the 3.55s I still think you should be alright, but you can always go bigger if you like. I would recommend getting a programmer since you can actually change the tire size on that to correct your speedo. You will also pump out an extra 40hp and 40ft/lbs, with a Diablo Sport Predator.
The difference in price between a 3rd gen and 4th is due to different suspension set ups from factory. The new Rams have an independent rear suspesnion which I guess causes the lifts to be a little more.
Old 03-16-2011, 09:46 PM
daytona691 daytona691 is offline
Vehicle: 2009 Dodge Ram 1500
Color: Inferno red
daytona691 is on a distinguished road
You should check out zoneoffroad.com they have fairly good prices a little more then rough country though
Old 03-16-2011, 10:57 PM
amcervantes amcervantes is offline
Vehicle: 2004 dodge ram 1500
amcervantes is on a distinguished road
I would second that dont get Rough Country. Im currently putting one on my truck and am having multiple problems with it this far. 1 wrong size washers for front crossmember. 2 directions are the crappiest in the world. 3 keeps saying to use provided nuts and bolts but which bag are they in cause they are numbered. 4 wrong size nuts and bolts for stinger bars. 5 supposed to be no cut kit but I have to now grind off part of the rear front crossmember ear cause the diff is hitting it slightly. 6 it says use MM sockets and wrenches but most sizes are two big and are in standard. 7 the bump stop extender looks like if it were ever to get bumped it would probably get crushed or break off. Oh yeah your going to need a 36mm socket for the CV nut which they neglected to inform me of. Just because its cheaper and has less parts doesnt always make it better. But then again everyone has their own experience.
Old 03-16-2011, 11:37 PM
dodgeguy's Avatar
dodgeguy dodgeguy is offline
Vehicle: 2000 Dodge Ram 1500
Rep:61
dodgeguy will become famous soon enough
I'm surprised that Big Horn hasn't chimed in yet... He's a member here, and he can get people fairly good deals from BDS.
If you go for a better company like BDS or Fabtech, the parts for the suspension will last longer, and will be better quality. I would highly recommend a better quality brand like one of those. You should probably get a steering stabilizer to go with whatever lift you get, just so you truck will be steadier on the road.
Also, they were right about 4 and 6 in lifts; there isn't much of a difference between the two. You would probably want bigger tires than you would on the 4" if you get the 6" though.
If you get bigger tires, you'll probably either need new rims with a negative offset or wheel spacers, so that the tires don't rub on the suspension parts. (A lot of guys on here will tell you that wheel spacers suck, but they aren't that bad if you don't go over 1/2" though)
If you go for the 4" lift, it might look ok without the tires on, but trust me, you'll get tired of looking at "too small" tires. If you get a 6", it'll just look stupid. You should probably wait until you can do the lift and tires at the same time.
The Diablo Tuner is a great option, even if you don't do the lift right away. It can help with gas mileage,, I've heard, and it can help you out in the power area, if you need it.
Depending on what gears you have, and what size tires you have, you might want to think about regearing. If you put on 37"s and only have 3.21, your truck will feel dead.
If you have put on 35"s and have 3.55s, you might be alright.
"If it's smaller than a 5-cyclinder, it's just a glorified motorcycle engine."
Old 03-18-2011, 11:54 PM
tuckertrucker's Avatar
tuckertrucker tuckertrucker is offline
Rep:34
tuckertrucker is on a distinguished road
Talking
I would check out TopGunCustomz.com They have everything you could consider for a lift from 1.5 spacers to 6in full lifts. Also you might want to think about that a 3in lift is about the limit you can go before you have to start changing out control arms, Pitman arm, sway bar drop bracket, track bar drop bracket, and the such. TopGun has a 3in coil lift I just got it comes with 2 front coils, 4 shockes, 2 lower control arms (not really needed but one of mine is bent) blockes for the rear and new u bolts. I paid about $550. Not a bad lift for the first time. Tire size and gearing, You could get away with stock gears with stock tires,(will look a tad funny with 3in lift) go 33in tires you can go with 4.10 gears, with 35in tires you go 4.56 gears, Dont forget you MUST change both front and rear gears CANT RUN DIFFERANT GEARS FRONT AND REAR things will break. This is just my OPINION I am no expert.
Tucker
1995 1500 4x4 360 3in lift 33 tires Magnaflow Gibson shorties Spectre CAI modded keg 52mm tb.
My truck has trouble starting... no one can figure out problem Pork Chop 3.7L PowerTech V6 Specific Topics 15 05-14-2011 10:14 PM
disappointed with my 2011 ram truck tomhrrs69 2011 Dodge Ram Forum 19 02-24-2011 10:38 AM
My new truck won't start again! rich1500 2010 Dodge Ram Forum 10 09-21-2010 01:28 AM
First time truck owner Kleeeen Newbie Checkin! 15 09-10-2010 11:47 PM
I love my truck! rjs2005 Dodge Ram General Discussion 14 10-03-2009 07:50 AM
