Old 06-07-2011, 04:19 AM
slimjim slimjim is offline
Vehicle: 99 4x qc150. 95.250 4x 5.9 gas
Trim Level: sport 150, slt 2500
Color: bl or gy
slimjim is on a distinguished road
I really like shak01's and crashes answer. It def. sounds like worn bearings too me from what you described. Can you milk it a week or month more? If you can follow shak01 instructions and find its full of sludge, probably yes, you can milk it along as long as the screen don't re-plug and you listen for the noise to not get worse. If its clean in the oil pan, you can run it longer than that. Just listen to the noise and as long as it doesn't get worse, keep the engine RPM's low and start making plans for a major repair or replacement. You may want to run a heavier oil or additive like Lucas if the oil pan is clean also. These magnums are likely the last motor that has the clearance to allow heavier oil run back too the oil pan. If that helps the noise, it absolutely is the bearings. You might just want to try and change the oil and filter before you do too much else though. If your confident it is the rod bearings, use the heavier oil too. Lifters tick, rods knock.
Old 11-04-2011, 01:49 AM
megaram06 megaram06 is offline
Vehicle: 2012 Ram 1500 Express 4x4
Color: Metalic dark blue
Rep:38
megaram06 is on a distinguished road
i had this same problem with my 98 dakota with the 318 magnum and i just recently started tearing the motor down and found the main bearings were worn out. so i replaced the bearings and the crank shaft and problem went away. hope this info helps
Old 11-04-2011, 02:27 AM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
sure sounds like bearings to me. my buddy just picked up a 99 durango with a rod knock, it was horrible when you 1st fired it up but it would kinda go away, when we drove it out to his ma's place to swap the motor, oil pressure would occasionaly drop and come back up. i got the motor for a core to build a 390 strocker out of, when i started tearin it down to just the bare block, the #1 connection rod bearing was gone and the crank jurnual was wore down
Old 11-05-2011, 03:00 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
as far as the earlyer question of Ting in so you can use both pressure sending unit and the micanical i would just to be sure. but one thing I do know about some 5.9's they do have problems with oiling and main bearings my dads 95 2500 4x4 blew main bearings 3/1 at 109,000. that was with reg dealer service from the time it was new.
Old 12-31-2011, 11:08 AM
2001MTXRam's Avatar
2001MTXRam 2001MTXRam is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: Laramie SLT Off-Road
2001MTXRam is on a distinguished road
Bad rod bearing will cause a knock, but it will not cause a drop in oil pressure. If the main bearings are bad it will definately cause you to lose oil pressure at idle. I wou ldnt drive it any more than I would have to. But depending on how long your main bearings have been bad, it will cause many other problems too with the clearence the crank has
Old 12-31-2011, 11:24 AM
ramfam's Avatar
Trim Level: Base
Rep:21
my brother's 95 2500 did the same thing. To a tee, it was 1/3 main bearing had both gone bad. They had worn to the brass and started to seze up.
Old 12-31-2011, 11:46 AM
primo spaghetti's Avatar
primo spaghetti primo spaghetti is online now
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
just as an aside
My 96 had the same drop in oil pressre and oil light illumination when i stopped (absent of any knocking noise you hear).
I just changed the oil pressure sensor and that fixed the drop in pressure and oil light at stops. While the knocking is definatly a concern, the sensor is the cheapest troubleshooting without tearing down a motor.
i guess what im saying is that the "drop" in oil pressure may not be related to any engine knock you hear on startup.
Old 03-16-2015, 10:17 PM
Arianajade Arianajade is offline
Vehicle: 2001 dodge 1500 4x4
Arianajade is on a distinguished road
I am having the same problems as the original topic post. What does the bled lifter have to do with the oil pressure drop? At start I have the noise but it also goes away. An the oil pressure drops when I stop but rises when I am driving or rev the engine while holding the brake. Any thoughts would be great I am at a lose.
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 05:29 AM
Oil pressure problems on my 01 1500 Ram 5.2 79JON 5.2L V8 Specific Topics 6 07-28-2010 11:43 AM
Oil pressure drops to zero jeff pearson 4.7L PowerTech V8 Specific Topics 11 07-11-2010 03:45 AM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 12:50 PM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 01:36 PM
