Old 06-10-2011, 02:23 AM
LuckysHemi LuckysHemi is offline
Vehicle: 2011 Ram 1500 SPORT CC
LuckysHemi is on a distinguished road
Default Bbk 90mm tb installed
I just installed the throttle body today. Install would be pretty simple if you just bolt the throttle body on. But it's never that simple write! The BBK 90mm is I would say 7 out of 10 quality wise. Casting is ok could be better I think but overall it's not bad. My install was a pain. Just because of the intake manifold. It's only 83mm I measured it with a micrometer. So I had to open the inlet up 7mm. I don’t think anyone could do that with this manifold there is just not enough material there to take off. I could only get the inlet to 88.7mm. O and I didn’t want to do this with the manifold on the truck so I took it off. It only takes about 30min to remove the manifold not bad at all. My truck only has 2073 miles on it and the inside of the intake manifold had oil every where. I was shocked on how much oil was in there from blow by. So after I cleaned everything up ported the intake manifold inlet and installed everything it took me about 4 hours. On first start up the truck idles a bit high for maybe 2 to 3 seconds then back to normal. Throttle response is a little better after a few revs. Power wise I would maybe say it's a little bit more responsive I would not really say there is a night and day difference in power but it is a little bit more peppy. My truck is a 2011 1500 Hemi CC sport. The engine is stock the only mod is has is a 180 t-stat everything else is stock. Also I did some before and after AFR readings at idle the truck stock was 14.8 with the 90mm TB it's now at 14.9 and at full throttle stock it was 11.6 and then it would taper down to 10.5 to 10.9 close to the redline. With the 90mm TB it stays at about 11.9 So I am pretty happy with this mod I well keep you all updated if anything changes. Thanks
Old 06-10-2011, 09:02 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:601
Man that's rich for a almost stock but maybe that's normal. I try to keep mine between 12.2-12.4 for WOT.
Old 06-11-2011, 11:51 AM
Yea very rich. Also just an update on the TB. Check engine light came on. Code is for "HIGH IDLE SPEED" i checked for vaccum leaks there are no leaks. So i am going to have the throttle recalibrated. I'll keep you all posted.
Old 06-13-2011, 09:29 AM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
...My truck only has 2073 miles on it and the inside of the intake manifold had oil every where. I was shocked on how much oil was in there from blow by.
Sound's like you need to get yourself a Catch Can
http://www.custombilletstore.com/Pro...ductCode=20010
I got this in just a few weeks..about 600 miles (a bit over 1.5 ounces)
Old 06-13-2011, 01:46 PM
Greg50Lt's Avatar
Greg50Lt Greg50Lt is offline
Vehicle: 2011 Ram 1500 Quad Cab 4x4
Trim Level: Sprot
Rep:20
Greg50Lt is on a distinguished road
That does sound rich for stock but Lean is MEAN. Just make sure that the AFR is ok. Maybe call a local shop or maybe someone on here who is an expert can let you know. Personally thats not that big of a difference so I wouldnt wory about it but you should have noticed a lil more power up top due to the truck running leaner.
OE: Nav/Alpine, Backup cam, brake controller, side steps Aftermarket:Bedliner, Tonnopro bed cover, Windows 20% Tails and Cab light tinted, 18in Magnaflow, Black Fuel Hostage 20x9 trail Grapplers 295-60R20, TGC 2.5 front spacer .75 rear, Billet fuel door
dealer installed trailer brake controller DenGent 2011 Dodge Ram Forum 37 08-17-2011 08:26 PM
My DYI CAI just installed GPSHSLAX Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 70 07-15-2011 12:57 AM
BBK 90mm, MSD coil kit, NGK IX Iriduims installed RamTex Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 23 05-31-2011 08:59 PM
CAI & Magnaflow installed PICS Trucks n Guns Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 7 04-25-2011 01:28 PM
Westin w-2-w installed crrcoal Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 5 03-13-2011 12:37 PM
