Old 03-17-2011, 11:46 AM
yimmortal yimmortal is offline
Vehicle: 2011 ram
yimmortal is on a distinguished road
Default inverter location
just got my new ram 3500.. the inverter is only rated at 150 watts. i want to put in a bigger one but keep the same outlet on the dash. does anyone know where the inverter is actually located so i can swap it out with a larger rated one?
please don't suggest just using a cigarette lighter one, or putting it under the seat or anything like that, that's just common sense. i want to replace it, not add an additional one
Old 03-17-2011, 12:11 PM
Rep:1885
Since you don't want one under the seat, I guess you won't be happy to hear that's where your factory unit is located.
REMOVAL
1.Disconnect and isolate the negative battery cable.
2.Release the seat cushion j-channel (1) from the seat frame to gain access to the power inverter module (2).
3.Lift up on the seat cushion and remove the four power inverter mounting bracket retainers.
4.Disconnect the power inverter electrical connector and remove the power inverter assembly from the vehicle.
5.Remove the four screws holding the power inverter to the mounting bracket.
6.Remove the power inverter.
Old 03-17-2011, 12:45 PM
I push the skinny pedal
Rep:3277
*Larry the Cable Guy Impression* Ok, I don't care who you are, that's funny right there.
Kurtis
Old 03-17-2011, 12:53 PM
Vehicle: 2011 ram
That's ok. I just didn't want to add an extra one. Which seat is it under? I'm hoping it looks like a common one that I could just swap out easily. But probably not knowing my luck. Hahaha
Old 03-17-2011, 01:13 PM
Rep:1885
Service info doesn't specify which seat and I haven't had to mess with one yet.
Old 03-17-2011, 02:29 PM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
I just looked under both front seats of my '10 CC. It looks to me as though it's mounted under the passenger seat. It looks very similar to the diagram that Randy posted, and if you feel along the top (sort of through the bracket) you can feel what feels like heat sink fins.
It doesn't look that hard to remove, though I don't think an after market inverted will fit in the same location, as they tend to be a bit larger.
If you're any good at electrical you might be able to somehow tap into the factory plug, and mount the new after market inverted somewhere else (there appears to be enough room under the driver's seat)
good luck
Exco
Bill
Old 03-17-2011, 07:23 PM
MOOSEFIRE66's Avatar
MOOSEFIRE66 MOOSEFIRE66 is offline
Vehicle: 2002 Dodge ram 1500 4X4 4.7L
Trim Level: SLT ??
Color: Fire Truck Red Baby!
MOOSEFIRE66 is on a distinguished road
I wanted to do the same thing. Let us know what brand inverter you went with, and how bad the install was if you fallow thru with this....
Aftermarket reverse lights, Emergency lights, New tires.......More to come!
Old 03-18-2011, 10:42 PM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
Don't forget to size the B+ wire for the heaver wattage output.
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 03-19-2011, 07:30 AM
Vehicle: 2011 ram
that's my next step is tracing wires and figuring out which ones i need to make heavier since the original wires look like they are only 14g or so does anyone have a wiring diagram?
1500 Watt Inverter markdido Dodge Ram General Discussion 2 01-24-2011 10:26 PM
Power Inverter Cormacs 2010 Dodge Ram Forum 11 03-28-2010 10:56 PM
New CB Radio Intall Location City Slicker Custom Dodge Ram Interior Modifications - Custom Audio / Video 16 01-24-2010 04:55 AM
Power inverter wattage bigdadsram 2010 Dodge Ram Forum 3 12-09-2009 09:32 PM
Alternate Location: May 30th Meet & Greet 300 Addict Dodge Ram Forum CANADA 4 05-28-2009 03:05 PM
