Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram – 2002 to 2008 Dodge Ram Trucks > Body & Interior
Old 03-17-2011, 03:13 PM
pjhaef's Avatar
pjhaef pjhaef is offline
Vehicle: 2004 Dodge Ram
Color: Atlantic Blue Pearl
pjhaef is on a distinguished road
Default Wheel Well Rust Repair
I am on day 3 of owning my truck and I am looking to get some opinions or advice on a body fix that will need to get taken care of. I have some rust just starting above the rear wheels at the top of the wheel well opening it has just started to bubble the paint but has not gone through the metal.
I was thinking of grinding down the affected area prime and paint so it is covered however instead of trying to repaint the box or trying to get the repair to match I was thinking of just adding some fender flares to it. I am thinking if I get the flares and know how much they cover and if I can keep the repair work to that area it may be ideal.
Let me here some thoughts on this and also give some feedback on what flares you have used and liked or disliked. I think I would go with the smooth finish ones as I am not crazy about the rivet or bolt on’s that show the hardware through the side.
Thanks in advance
PJ
Old 03-18-2011, 10:34 AM
oh4ohyeah's Avatar
oh4ohyeah oh4ohyeah is offline
Vehicle: 2004 Dodge Ram 1500 Quad Cab
Rep:88
oh4ohyeah will become famous soon enough
I was actually just getting to post this exact same topic. I have a 2004 and I'm also looking for opinions on doing exactly this (rust repair, paint and flares). My rust bubbles just started right before winter here in Ohio and now they're progressing pretty rapidly so I need to get started soon! I'm fairly inexperienced when it comes to body work, but I know a little about it and I'm ready and willing to start this project and learn at the same time. I'm subscribing to this thread! Thanks!
Good Hood Fiberglass Functional Ram-Air Hood * Gibson Stainless Headers * Magnaflow Dual Exhaust * Nitto Terra Grapplers * 20% Window Tint
Old 03-20-2011, 09:51 PM
pjhaef's Avatar
I understand what you are looking at. I want to get this done in some fashion before it starts to get real ugly. I will update the post as we go along but at this time I am still deciding what flare to get but I figure I will have something on order in the next week or so. I am waiting on the rest of the snow to get out of here and allow things to dry and warm up a bit so it will be easier to do the work.
More info to come as this project goes but if anyone has some insight I would be glad to here it.
Old 04-26-2011, 01:56 PM
RangerCoach RangerCoach is offline
Vehicle: 2003 Dodge Ram Quad Cab
Trim Level: Standard
RangerCoach is on a distinguished road
Exclamation Be Aware
Be carefull where you go here. I have a 2003 Quad Cab with the exact same issue. The problem is this is a design flaw up to about 2006 where the inner bed liner rust through to the outside. You are only seeing the tip of the iceberg. The only way to correctly repair this is to replace the side panels of the bed. My estimate was 3800! I am talking to Chrysler now to see if they will do anything but I don't know...
Old 04-26-2011, 04:30 PM
Stusmobile Stusmobile is offline
Vehicle: 2013 Quad Cab
Rep:98
Stusmobile will become famous soon enough
I'm in the same place with my 2002 but I have come up with a multi stage plan to at least minimize the issue down the road.
Wheels off, the inside of the fenders are getting cleaned out, rust treated (POR 15) and then sealed with about a quart of bedliner (herculiner or bed armor probably).
Outside the rust already showing will get cleaned, treated, filled and repainted and then the flares will get added.
I'm hoping that long term this will help with the rust coming from under the fender, time will tell.
Old 04-26-2011, 09:12 PM
maybz maybz is offline
Vehicle: 2007 Dodge Ram Laramie
maybz is on a distinguished road
my brother's 03 went the same way. He just replaced both box panels. The true way to fix the problem but it cost him $3000. There is three holes in the lip of the wheel well soak the oil to them. My 07; hopefully doesn't do the same. I was thinking of putting on some rear inner wheel well liners : thinking this might hold out some salt. They are $115 from Mopar here in Canada. Was wondering if any one else has put them on
Old 05-02-2011, 01:57 PM
bmacknyc1k bmacknyc1k is offline
Trim Level: Hemi Sport
bmacknyc1k is on a distinguished road
I just had the same problem, picked up an 04 hemi sport with only 50k miles, clean, except for this issue, paint bubbling around the rear wheel wells......the truck also had fender flares on it, the chrome ones which have been taken off, these will trap alot of stuff back there as well like salt...
my friend owns a body shop, to repair the box sides, grind all of the rust out and/or sanblast meticulously, and use POR 15 on the rust affected areas, then prime and prepare for paint....
the whole trick of repairing them is to do it while you still have metal to grind off the rust and blast it well, POR 15 will help as well, stops rust in its tracks.....but it is not cheap, like 45 bucks a pint i think....
Old 04-07-2012, 03:55 PM
rusty nuts rusty nuts is offline
Vehicle: 2003 ram hemi
Trim Level: larimine
Color: rust
rusty nuts is on a distinguished road
Has any one tried the flares over the wheels, which ones look the best?
Old 04-09-2012, 12:30 PM
RedneckMechanic RedneckMechanic is offline
Vehicle: 2002 Dodge Ram 1500 4x4
Rep:28
RedneckMechanic is on a distinguished road
I'm in the same boat. I'm looking at chipping out the rust as much as I can without making a gaping hole, but some rust inhibitor on it, prime it and put a flare over it. May have to get some tall flares, but... Cheaper than the $3K for new bedsides...
Old 04-09-2012, 08:10 PM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2004 dodge ram 1500
Rep:31
charlieb is on a distinguished road
bushwacker flares are biggest 1s.http://www.bushwacker.com/
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
rust repair panels from LETP raider9701 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 1 02-20-2011 06:23 PM
rust on front wheel vided 2010 Dodge Ram Forum 5 01-29-2011 09:41 PM
rust over wheel wells crbond Body & Interior 8 06-07-2010 04:32 PM
Rust Repair Ruffian11 Rust Repair 3 04-18-2010 11:37 PM
