United Radio
Old 03-17-2011, 07:20 PM
Jrob7106 Jrob7106 is offline
Vehicle: 2004 dakota
Color: Patriot blue
Jrob7106 is on a distinguished road
Default stereo issue on 99 3500
I am working on a 99 3500 ram ext cab with cummins. The front speakers (doors and tweeters) do not work. Tried installing an aftermarket head unit, still do not work, neither does the cd function on the unit or auxillary mp3 jack. The fm tuner does work and only gets sound out of rear speakers. Any suggestions?
Old 03-25-2011, 02:58 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Sounds like there may be problems in the factory harness
Old 03-25-2011, 09:02 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Sounds like the factory amps are not getting turned on. There should be a wire that is not part of the regular harness, black and blue one. THis will need to go to the power antennae wire on the aftermarket stereo.
Old 10-17-2011, 03:31 PM
itsavant itsavant is offline
Vehicle: 1998 Dodge Ram 2500 4X4
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
itsavant is on a distinguished road
Is this black/blue wire you speak of, by itself and connected to the frame of the factory radio with a spade type connector? i thought that was a ground? Maybe thats why i don't have sound from all speakers.
Old 10-21-2011, 01:29 AM
camoman214 camoman214 is offline
Vehicle: None right now
camoman214 is on a distinguished road
The factory amps are not coming on. Wernbang is right, however I wouldn't use the "power antenna" feed because on most after-market CD players, the power antenna feed loses all voltage when the CD player is set to CD mode or any other mode that isn't the AM/FM radio. I would use the wire labeled "amp power" which is normally solid blue. This wire is always powered when the CD player is on and will give power to your stock amps whether you are on AUX mode, AM/FM mode or CD mode.
This is also the reason why you are only getting sound in AM/FM radio mode.
Pioneer AVIC-Z110BT Install into a 09 1500 marko7717 Dodge Ram Knowledge Base 19 08-29-2012 04:52 AM
Vibration Issue WickedSix 5.7L V8 Specific Topics 5 01-13-2011 12:30 AM
2004 Dodge Ram 3500, AC Issue, doesn't blow hard Texas Heating & Cooling 3 08-15-2010 10:35 AM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 12:50 PM
Stereo issue: Cassette system jammed... JayRAudetteJr Body & Interior 10 01-08-2010 01:51 PM
